Zeeman magnet power power supply is not operating properly.
In the Furnace page of the Diagnostics window click on the Reconnect button and allow the system to reinitialize. If the problem persists, follow the instructions below.
Shut down the application software (WinLab).
Power down the instrument's front panel switch.
Unplug the instrument from the power source for 30 seconds.
Reinitialize instrument and retry.
If error re-appears during analysis, modify temperatures and/or
cycle times to prevent overheating.
[0407]
我石墨炉测镉时 连续开机就2h差不多就出现这个问题
