EXPNO: experiment number
PROCNO: product number
Date-Time:the date and time of measurement
INSTRUM:spect
PROBHD:probhead type
PULPROG:pulse programme
TD:time domain size
SOLVENT:
NS:numbers of scan
DS:dummy scan
SWH(Hz):Sweep width in Hz
FIDRES:
AQ:acquisition time
RG:receiver gain
DW:dwell time
DE:pre-scan-delay
TE:temperature
D1:relaxation delay, 1-5*T1
TD0: dimension of accumulation loop
----------------f1channel---------------
Nuc1:Nucleus for channel 1 ----1H
P1:F1 channel- 90 degree high power pulse
PL1:F1 channel- power level for pulse (default)
SFO1:Frequency of observe channel
SI:Size of real spectrum
SF:Spectrometer frequency
WDW:window functions for trf, xfb….
SSB:Sine belt shift SSB(0,1,2,…)
LB:Line broadening for em
GB:Gaussian max, position for gm, 0<GB<1
PC:Peak detection sensitivity for pp
该帖子作者被版主
kcq1997加 2积分,
2经验,加分理由:积极回答
