单位购买的waters 的Synapt HDMS Q-tof 使用了一年半了,和大家分享一下使用的心得。也为准备购买waters 的G2 HDMS Q-tof 的单位做一些介绍。
仅为个别经验,仅供参考,不代表单位的意愿。
不好意思使用个G2的图代替,因为两款仪器的结构几乎差别不了什么。
这款仪器的官方数据为:
Second-generation MALDI SYNAPT™ G2 HDMS™ is a flexible research platform that can provide the ultimate in quantitative and qualitative performance with exact mass UPLC
®/MS/MS in TOF mode and the ability expand your analytical capabilities beyond conventional mass spectrometry, combining MALDI with high-performance exact mass MS/MS and high-efficiency ion mobility separations.
HDMS-mode:- Triwave™ Technology: provides enhanced ion mobility separation power and access to its unique benefits in conformational studies, analysis of isomers, reduces sample complexity, increases peak capacity, and enhances information from fragmentation studies.
- Facile determination of molecular collision cross-section (shape).
- Time aligned parallel (TAP) fragmentation: provides comprehensive structural (MS/MS/MS) information in a single experiment.
- DriftScope™ Mobility Environment Software (v. 2.1): for interactive visualization and manipulation of multidimensional data.
- HDI™ (High Definition Imaging): the extra dimension of separation provided by the MALDI SYNAPT HDMS System can be used to produce images without interference from background ions of similar mass, leading to more precise localization of a drug or metabolite of interest. Ions are separated using ion mobility (IMS) prior to mass analysis.
ToF mode:- IntelliStart™ Technology: for simplified system setup and automated system control.
- ACQUITY UPLC® Technology: for the highest chromatographic resolution, speed, and sensitivity.
- QuanTof™ Technology: ensures you’ll capture the most complete and informative exact mass data in UPLC® timeframes, complemented by UPLC/MSE capability to capture all of the data all of the time.
- MassLynx™ Informatics: combines the power of exact mass data and a built-in understanding of chemistry to deliver simple and rapid data interpretation and compound identification.
解读如下:
1。 HDMS 模式
HDMS是说仪器的高分辨率质谱的那部分。仪器采用TOF“V”模式时候就可以实现高分辨率质谱,在温度和湿度恒定的条件下,仪器的质量分辨率可以达到0.2ppm左右,这是我测定40多种分子量在800~1200标准品,得到的数据。
所以说仪器的HDMS还是很过关的。
仪器采用了实时的校正功能,使用LE(亮氨酸脑啡肽)作为校正液,可以没半分钟自动校准一次仪器,保证了仪器的精确质量测定的准确可控。
2. DriftScope™ Mobility Environment Software (v. 2.1)
这款软甲是用于离子淌度功能的数据分析的,做出的离子淌度的分析图非常的“炫丽”,贴在研究报告中非常具有捕捉观众眼球的功能。能够根据动量守恒的原理。将带有不同电荷数的离子进行离子淌度分离。分离是在瞬间进行的,速度很快,效果较明显。根据该软件分析得出的数据,不同的离子将在图谱中以不同的斜率表示出来,很直观。
3.HDI™ (High Definition Imaging)功能
大家还在进行传统的液质联用的实验的时候,在世界的另一边已经有很多人在直接使用Maldi离子源,将大块的活生生的肉堆在质谱上,进行数据扫描。最终的到的是这块肉的化学成分,立体图像。
这对于医学和食品科学的推动是巨大的,医学院一直采用的是核磁共振成像技术,只是对人体的H元素进行成像,无法解释人体内部其他化学成分对健康的影响。如果使用这种技术,将更加直观的发现和解决人类的众多疑难问题。
在食品安全方面,这样的技术大大的加快了食品安全的监控,能够不用前处理,直接分析样品,而且不受方法的限制,直接筛查样品中的化学成分。
4.IntelliStart™ Technology
这是仪器自动化的智能程序。在waters 的今年来新的其他仪器上均有嵌入。这种功能非常的实用,可以减少人力的消耗,可以自动完成仪器的开启和预热,平衡和关闭。还有仪器中寻找质谱信号的工作也可以交给这个程序。我的使用经验是,吧所有的程序编写好,基本可以回办公室了,软件自动的操作仪器,分析数据。完全减轻了我的工作。
