Inject equal volumes (1ml gaseous phase) from Blank, standard & sample (HSS) vial and record the Area of Methanol, Isopropyl alcohol, Ethyl acetate and To;uene. Calculate the theoretical plate, Resolution and Relative standard deviation.
从空白溶液、标准溶液和样品溶液中分别吸取相当于1ml
气相的溶液进样,记录甲醇、异丙醇、乙酸乙酯和甲苯的峰面积。计算理论塔板数、分离度和相对标准偏差。
不知道Inject equal volumes (1ml gaseous phase)翻译成“分别吸取相当于1ml
气相的溶液进样”对不对。
