主题:【讨论】Aroclor 1016和 Aroclor 1242的区别在
浏览0 回复4 电梯直达
paraffin
The only North American producer, Monsanto, marketed PCBs under the trade name Aroclor from 1930 to 1977. These were sold under trade names followed by a 4 digit number. The first two digits generally refer to the number of carbon atoms in the biphenyl skeleton (for PCBs this is 12), the second two numbers indicate the percentage of chlorine by mass in the mixture. Thus, Aroclor 1260 has 12 carbon atoms and contains 60% chlorine by mass. An exception is Aroclor 1016, which also has 12 carbon atoms, but has 42% chlorine by mass.。
这样看来1016和1242没啥区别了啊?没找到相关文献,不知有谁知道差异?
阿宝
symmacros
从字面上看两者还是有区别的,含氯量不同。
1016 CAS No.12674-11-2  PCB C12H8CL2 和 C12H7CL3
1242 CAS No.53469-21-9      PCB C12H8CL2, C12H7CL13 及 C12H6CL4
深蓝
原文由 symmacros(jimzhu) 发表:
朱老师,这个1016是混标的意思喽?而且从这里面也看不出具体结构,是这样吗?
forth
原文由 深蓝(mitsumi) 发表:
两者都是多氯联苯混合物,但是成分不同,是两个产品线出来的东西。
