以下内容来自网络
General column for most popular applications, particularly for petroleum and petrochemical industries
100% Poly(dimethylsiloxane), cross-linked and bonded
Solvent rinse-able and high temperature limit
Low column bleed, inert and neutral surface, high plate number
Wide range of column dimensions and stationary phase film thicknesses
Non-polar, equivalent to USP G1, G2, G38
Similar Phases: DB-1, HP-1, Ultra-1, SPB-1, RTX-1, CP-Sil 5CB, BP-1, ZB-1, AT-1, MDN-1, OV-1, OV101, Optima-1
这个柱子和DB-1是类似的,非极性柱子
