3. Where the presence of moisture or other volatile material may interfere with the procedure, previous drying of the substance is specified in the individual monograph and is obligatory.
4. The term “solvent-free” signifies that the calculation shall be corrected for the presence of known solvents as determined using the methods described in Residual Solvents <467> unless a test for limit of organic solvents is provided in the monograph.
