方法包括:
NOAA_NST130.00 Capillary gas chromatography analysis for organic contaminates in marine sediments.
NOAA_NST130.01 Organic contaminates in marine animal tissues by GC-FPD
EPA150.1 pH in Water by Electrometric Method
EPA150.2 pH in Water
EPA1624 Volatile Organic Compounds by GC/MS
EPA508A PCBs by GCECD
EPA524.2 VOCs in Water Using GCMS
EPA525.2 Organics in Water Using GCMS
EPA526 SVOCs in Water by GCMS
EPA528 Phenols in Water by GC/MS
EPA550 PAHs in Water Using HPLC/UV/FL
EPA550.1 PAHs in Water Using HPLC/UV/FL
EPA551.1 Chlorinated Compounds in Water Using GC-ECD
EPA8100 Polynuclear Aromatic Hydrocarbons in Water and Solid Samples by GC-FID
EPA8141B Organophosphorus Compounds in Water, Soil, and Waste Samples by GC-NPD
EPA8141B Organophosphorus Compounds in Water, Soil, and Waste Samples by GC-FPD
这是我自己平时收藏的,与大家分享了!
17种分析方法(英语)
