该分离柱为说明书上有这么一段: Maximum pressure over the packed bed during operation 0.3MPa, 3 bar, 42 psi HiLoad column hardware pressure limit 0.5MPa, 5 bar, 73 psi
2. 系统: 岛津10AHPLC系统,配件有 LC-10ADvp Liquid Chromatogragh LC-10AP Auto Injector RID-10A RID SCL-10Avp System Controller FRC-10A Fraction Collector
3. 工作参数: 流速:3.0 ml/min 流动相:0.15 M 甲酸铵 样品:0.1 g/ml 麦麸初提掖 进样量:10 ml
