主题:【求助】注射液用高效液相怎么检测??
浏览0 回复2 电梯直达
liuqiasnqia
土霉素注射液用高效液相怎么检测?谢谢!
kylabs
注射用土霉素的稳定性分析方法:
ColumnCogent Bidentate C18™, 4µm, 100A
Catalog No.40018-75P
Dimensions4.6 x 75 mm
SolventsA: DI water + 0.1% formic acid
B: acetonitrile + 0.1% formic acid
Gradient
time (min.)%Btime (min.)%B
010680
430710
Post time3 min.
Flow rate1.0 mL/min.
SampleUSP grade tetracycline HCl capsule extract (degraded).
Stock Solution: 10.0 mg capsule contents were diluted with 10 mL 1.0 N HCl and sonicated for 10 min. 1 mL aliquot was diluted to 20 mL with DI water. Solution was heated at 80°C for 30 min. Solution was then diluted to 100 mL with DI water and filtered through a 0.45 µm nylon membrane HPLC filter (MicroSolv Technology Corp., Eatontown, NJ, USA).
Working Solution: Stock solution was diluted 10x using 0.01 N HCl diluent.
DetectionUV 360 nm (0? min) 430 nm (5? min)
该帖子作者被版主 boboenid0072积分, 2经验,加分理由:很热心的版友!
2011/5/24 21:33:24 Last edit by kylabs
kylabs
