中文 | 英文 | 缩写或简称 |
优级纯试剂 | Guaranteed reagent | GR |
分析纯试剂 | Analytial reagent | AR |
化学纯试剂 | Chemical pure | CP |
实验试剂 | Laboratory reagent | LR |
纯 | Pure | Purum Pur |
高纯物质(特纯) | Extra pure | EP |
特纯 | Purissimum | Puriss |
超纯 | Ultra pure | UP |
精制 | Purifed | Purif |
分光纯 | Ultra violet Pure | UV |
光谱纯 | Spectrum pure | SP |
闪烁纯 | Scintillation Pure | |
研究级 | Research grade | |
生化试剂 | Biochemical | BC |
生物试剂 | Biological reagent | BR |
生物染色剂 | Biological stain | BS |
生物学用 | For biological purpose | FBP |
组织培养用 | For tissue medium purpose | |
微生物用 | For microbiological | FMB |
显微镜用 | For microscopic purpose | FMP |
电子显微镜用 | For electron microscopy | |
涂镜用 | For lens blooming | FLB |
工业用 | Technical grade | Tech |
实习用 | Pratical use | Pract |
分析用 | Pro analysis | PA |
精密分析用 | Super special grade | SSG |
合成用 | For synthesis | FS |
闪烁用 | For scintillation | Scint |
电泳用 | For electrophoresis use | |
测折光率用 | For refractive index | RI |
显色剂 | Developer | |
指示剂 | Indicator | Ind |
配位指示剂 | Complexon indicator | Complex ind |
荧光指示剂 | Fluorescene indicator | Fluor ind |
氧化还原指示剂 | Redox indicator | Redox ind |
吸附指示剂 | Adsorption indicator | Adsorb ind |
基准试剂 | Primary reagent | PT |
光谱标准物质 | Spectrographic standard substance | SSS |
原子吸收光谱 | Atomic adsorption spectorm | AAS |
红外吸收光谱 | Infrared adsorption spectrum | IR |
核磁共振光谱 | Nuclear magnetic resonance spectrum | NMR |
有机分析试剂 | Organic analytical reagent | OAS |
微量分析试剂 | Micro analytical standard | MAS |
微量分析标准 | Micro analytical standard | MAS |
点滴试剂 | Spot-test reagent | STR |
气相色谱 | Gas chromatography | GC |
液相色谱 | Liquid chromatography | LC |
高效液相色谱 | High performance liquid chromatography | HPLC |
气液色谱 | Gas liquid chromatography | GLC |
气固色谱 | Gas solid chromatography | GSC |
薄层色谱 | Thin layer chromatography | TLC |
凝胶渗透色谱 | Gel permeation chromatography | GPC |
层析用 | For chromatography purpose | FCP |
