"尽量选择卡片数字大的"比较有道理,但看score选就不合适了~~
其实可以打开卡片的内容,查看里面的评价,比如这个:(我随手查了以下SiO2)
Status, subfiles and quality
Status: Marked as deleted by ICDD
Subfiles: Inorganic
Mineral
Alloy, metal or intermetalic
Quality: Blank (B)
Comments
Deleted by: Berry parcel of March 25, 1962 (for 14-260).
Color: Colorless
General comments: Specimen was Haws Refractory Brick.
Low tridymite occurs in many polytypic forms, the patterns of which are characterized by the same strong reflections and different weak ones.
Optical data: A=1.478, B=1.479, Q=1.481, Sign=+, 2V=35
从上面我们可以注意到这么一句:Marked as deleted by ICDD,而在后面的COMMENTS里可以找到Deleted by: Berry parcel of March 25, 1962 (for 14-260).
这样我们可以调出14-260,查看它的质量:
Subfiles: Inorganic
Common Phase
Forensic
Quality: Indexed (I)
Comments
Deleted by: Deleted by 50-1431, higher FN & QM; LRB 8/99.
还不是好的,同样的方法,继续调50-1431
Subfiles: Inorganic
Common Phase
Forensic
Quality: Star (S)
这回真正找到需要的了
原文由 morype 发表:
我用的也是它家的Highscore。对这个问题也有一些疑惑。
目前我的方法是尽量选择卡片数字大的,因为卡片号越大数据准确性越好(之前一个培训工程师说的)。
同时,如果还是觉得不好,我就会看软件里面的score参数,这个score代表的是fit的程度,也是score数字越大,fit就更好。
