主题:【分享】Results部分的写法
省部重点实验室
Tags:
      Results段落是客观地讲述实验结果, 一般不加讨论和解释. 写作方法应注 意以下几点:
            1用过去语句.
            2.  有的学科只用文字来讲述实验结果, 但大部分学科往往添加 Figure Table来帮助组织数据.
            3.  Figure Table 要分别给予序号, 不统一排序.
4.  Table 要有个题目, 题目就写在Table的上方. 注解文字写在Table的下方.  Table有时需要照排版,所以草稿中的Table要单独成页. Table 应该附在稿件的后面, 如放在References之后.例如:
Table 1.  Compound A and compound B affinity for human and mouse melanocortin receptor subtypes
        _________________________________________________________________________
                                            pKi (Ki, nM)
        Receptor                Compound A                Compound B
        Human MC1                        7.39                            8.09
        Human MC2                        7.21                            5.93
        Human MC4a                      6.13                            6.53
        Mouse MC1                        9.02                          5.68
        Mouse MC2                        7.51                          8.03
        Mouse MC4a                      5.63                            5.89
        __________________________________________________________________________
The affinity of ligands for melanocortin receptors in HEK cell membrane was measured by inhibition of [125I]-MSH binding, as described in Methods.  a, CHO cell line was used.
5.      也是考虑到排版的需要, 杂志要求草稿中的每个 Figure 要单独占一页, 并且这一页只是Figure 把序号写在Figure页的背面. Figure应该附在 稿件的后面, 如放在References之后. 例如:
6.  Figure的说明(Figure Caption) 要单独写, 不同Figure放在一起,一般可以放在Refences部分之前或之后. 但不同Figure的说明可以 排在一起. Figure说明中只写介绍Figure的文字,不对Figure的结果进行解释.例如上面Figure例子的说明:
            Figure Captions
Figure 2. Time course of broth volume () and dry cell weight (DCW, ○) in repeated fed-batch fermentation of penicillin G. From 60 h to finish, the working volume was controlled in the range of 72–80 m3, 8.0 m3 of broth was drawn off at a 24 h interval with the mycelium concentration (DCW) kept stable. Data was the average of 16 batches.
            7方程式一般给一个序号, 写在方程的右边的括号中, 例如:
                The distance traveled is given by S:
                S = v t        (1)
                where v is velocity and t is time.
yuduoling
手机版: Results部分的写法
