Precision ≤0.07 % RSD,or ≤0.02 min SD whatever is greater, based on retention time at constant room temperature Flow accuracy ± 1 % or 10 µL/min whatever is greater
Range Setpoints from 0.001 to 10.0 mL/min, in 0.001 mL/min increments Pressure Operating range 0 - 40 MPa (0 - 400 bar, 0 - 5880 psi) up to 5 mL/min0 - 20 MPa (0 - 200 bar, 0 - 2950 psi) up to 10 mL/min Pulsation <2 % amplitude (typically <1 %) at 1 mL/min isopropanol at all pressures >1 MPa (> 10 bar, >147 psi) Compressibility compensation User selectable, based on mobile phase compressibility Recommended pH range 1.0 - 12.5Solvents with pH <2.3 should not contain acids which attack steel
