Should it be read as :
and measure the peak areas as directed for [Procedure: …… ]
For information :
The chromatograph is programmed as follows: the temperature of the column is maintained at 508 for 5 minutes, then the temperature is increased at a rate of 58 per minute to 2008 and maintained at the 2008 for 15 minutes; the vial is heated to 908 for 60 minutes, the transfer line is heated to 1508, and the injection port and the detector block are maintained at a temperature of 2508. Chromatograph the Resolution solution, and record the peak areas as directed for [Procedure: the resolution, R, between ethyl benzene and pxylene is not less than 1.5.]
Chromatograph the Standard solution, and record the peak areas as directed for [Procedure: the relative standard deviation of the ethylhexyl triazone peak for replicate injections is not more than 10.0%.]
