主题:【每日一句(段)有奖翻译】<四十七>Testing Practices And Procedures (3-3)
浏览0 回复2 电梯直达
影子
Alt-ernative and Harmonized Methods and Procedures
6. Therefore, if a substance or preparation is found to comply with a requirement using an interchangeable
method or procedure from one of these pharmacopeias, it should comply with the requirements of the USP.
7. When a difference appears, or in the event of dispute, only the result obtained by the method and/or
procedure given in the USP is conclusive.
天黑请闭眼
6. 因此,如果一种物质或者一种制备方法遵循的要求来自于其它药典中的替代性方法或程序,那么它应当符合美国药典的要求。
7. 如果(其它药典和美国药典)有所不同或者有冲突,只有依照美国药典给出的方法和(或)程序得到的结果才是确凿可信的。
该帖子作者被版主 hyheying5积分, 2经验,加分理由:幸好有人翻出来,忘了加分了,补上!
笨笨的唯一
啊,我有望尘莫及的感觉,要怎么样才能赶上大家呢?看来还是得多加努力哇
