组分 | 标准值 | 标准偏差 | 单位 |
Ag | 0.14 | 0.02 | (10-6) |
Al2O3* | 17.85 | 0.12 | (10-2) |
As | 18 | 2 | (10-6) |
B | 63 | 4 | (10-6) |
Ba | 411 | 18 | (10-6) |
Be | 3.8 | 0.3 | (10-6) |
Bi | 1.44 | 0.11 | (10-6) |
Br | 2.6 | 0.3 | (10-6) |
CaO* | 0.40 | 0.04 | (10-2) |
Cd | 0.25 | 0.02 | (10-6) |
Ce | 133 | 5 | (10-6) |
Cl | 78 | 6 | (10-6) |
CO2* | (0.1) | (10-6) | |
Corg. | 0.97 | 0.12 | (10-6) |
Co | 13.6 | 0.6 | (10-6) |
Cr | 67 | 3 | (10-6) |
Cs | 13.9 | 0.7 | (10-6) |
Cu | 32 | 2 | (10-6) |
Dy | 7.4 | 0.5 | (10-6) |
Er | 3.8 | 0.2 | (10-6) |
Eu | 1.66 | 0.07 | (10-6) |
F | 790 | 44 | (10-6) |
FeO* | (0.8) | (10-2) | |
Ga | 25.1 | 1.2 | (10-6) |
Gd | 8.5 | 0.7 | (10-6) |
Ge | 1.7 | 0.12 | (10-6) |
H2O+* | (5.8) | (10-2) | |
Hf | 8.2 | 0.4 | (10-6) |
Hg | 0.46 | 0.05 | (10-6) |
Ho | 1.41 | 0.08 | (10-6) |
I | 1.3 | 0.1 | (10-6) |
In | 0.095 | 0.027 | (10-6) |
K2O* | 2.5 | 0.04 | (10-6) |
La | 67 | 3 | (10-6) |
Li | 51 | 3 | (10-6) |
Lu | 0.58 | 0.05 | (10-6) |
MgO* | 0.84 | 0.05 | (10-2) |
Mn | 441 | 20 | (10-6) |
Mo | 1.15 | 0.07 | (10-6) |
N* | 0.102 | 0.011 | (10-2) |
Na2O | 0.33 | 0.02 | (10-2) |
Nb | 26 | 1 | (10-6) |
Nd | 57 | 4 | (10-6) |
Ni | 27.4 | 0.9 | (10-6) |
P | 972 | 34 | (10-6) |
Pb | 61 | 2 | (10-6) |
Pr | 14.6 | 1.1 | (10-6) |
Rb | 173 | 5 | (10-6) |
Re | (0.15) | (10-9) | |
S* | 261 | 26 | (10-6) |
Sb(DA) | 1.7 | 0.2 | (10-6) |
Sb(T) | (1.9) | (10-6) | |
Sc | 14 | 0.5 | (10-6) |
Se | 0.51 | 0.05 | (10-6) |
SiO2* | 63.81 | 0.16 | (10-2) |
Sm | 14 | 0.5 | (10-6) |
Sn | 12.4 | 0.8 | (10-6) |
Sr | 68 | 4 | (10-6) |
Ta | 2.8 | 0.2 | (10-6) |
Tb | 1.3 | 0.1 | (10-6) |
TFe2O3* | 5.44 | 0.05 | (10-2) |
Th | 28 | 2 | (10-6) |
Ti | 0.578 | 0.026 | (10-2) |
Tm | 0.57 | 0.05 | (10-6) |
U | 5.9 | 0.3 | (10-6) |
V | 105 | 4 | (10-6) |
W | 5.8 | 0.2 | (10-6) |
Y | 38 | 3 | (10-6) |
Yb | 3.8 | 0.2 | (10-6) |
Zn | 100 | 8 | (10-6) |
Zr | 275 | 11 | (10-6) |
原文由 lilongfei14(lilongfei14) 发表:
【说明】密封性良好的玻璃瓶
【保存条件】密封保存在阴凉干燥处。
【使用注意事项】最小取样量为0.1克。
【特征形态】固态
【基体】土壤
【主要分析方法】等离子体质谱法,等离子光谱法,原子吸收(火焰发射)法等
组分 标准值 标准偏差 单位 Ag 0.14 0.02 (10-6) Al2O3* 17.85 0.12 (10-2) As 18 2 (10-6) B 63 4 (10-6) Ba 411 18 (10-6) Be 3.8 0.3 (10-6) Bi 1.44 0.11 (10-6) Br 2.6 0.3 (10-6) CaO* 0.40 0.04 (10-2) Cd 0.25 0.02 (10-6) Ce 133 5 (10-6) Cl 78 6 (10-6) CO2* (0.1) (10-6) Corg. 0.97 0.12 (10-6) Co 13.6 0.6 (10-6) Cr 67 3 (10-6) Cs 13.9 0.7 (10-6) Cu 32 2 (10-6) Dy 7.4 0.5 (10-6) Er 3.8 0.2 (10-6) Eu 1.66 0.07 (10-6) F 790 44 (10-6) FeO* (0.8) (10-2) Ga 25.1 1.2 (10-6) Gd 8.5 0.7 (10-6) Ge 1.7 0.12 (10-6) H2O+* (5.8) (10-2) Hf 8.2 0.4 (10-6) Hg 0.46 0.05 (10-6) Ho 1.41 0.08 (10-6) I 1.3 0.1 (10-6) In 0.095 0.027 (10-6) K2O* 2.5 0.04 (10-6) La 67 3 (10-6) Li 51 3 (10-6) Lu 0.58 0.05 (10-6) MgO* 0.84 0.05 (10-2) Mn 441 20 (10-6) Mo 1.15 0.07 (10-6) N* 0.102 0.011 (10-2) Na2O 0.33 0.02 (10-2) Nb 26 1 (10-6) Nd 57 4 (10-6) Ni 27.4 0.9 (10-6) P 972 34 (10-6) Pb 61 2 (10-6) Pr 14.6 1.1 (10-6) Rb 173 5 (10-6) Re (0.15) (10-9) S* 261 26 (10-6) Sb(DA) 1.7 0.2 (10-6) Sb(T) (1.9) (10-6) Sc 14 0.5 (10-6) Se 0.51 0.05 (10-6) SiO2* 63.81 0.16 (10-2) Sm 14 0.5 (10-6) Sn 12.4 0.8 (10-6) Sr 68 4 (10-6) Ta 2.8 0.2 (10-6) Tb 1.3 0.1 (10-6) TFe2O3* 5.44 0.05 (10-2) Th 28 2 (10-6) Ti 0.578 0.026 (10-2) Tm 0.57 0.05 (10-6) U 5.9 0.3 (10-6) V 105 4 (10-6) W 5.8 0.2 (10-6) Y 38 3 (10-6) Yb 3.8 0.2 (10-6) Zn 100 8 (10-6) Zr 275 11 (10-6)
