主题:【原创】投稿外文期刊请慎重推荐审稿人——请看我的投稿遭遇吧。
浏览0 回复3 电梯直达
gbluo324
一篇稿子,投到英国一影响因子4左右的杂志,一大修一拒稿,出版编辑给出拒稿结论;按照修改意见改了改投美国一影响因子1多一点的杂志,很快就拒稿。下面贴出我的这篇杂志拒稿信。(请看下文红色部分)
After a careful reading of the manuscript, I regret to inform you that I have decided against publication. XXXXX  publishes novel papers on various aspects of A . I sent your paper out for review and one of the reviewers let me know that he had previously received your paper from a different journal and had recommended rejection based on lack of novelty. Since no changes had apparently been made to your manuscript, I am rejecting your paper for the same reason.
我两次投稿都选择了同一美国某大学教授,华人,两次编辑都采用了我的推荐审稿人,悲剧就发生了。当然,这跟我的稿子创新不够关系也比较大。不过,后者只看了这个审稿人的拒绝审稿意见就直接拒了,唉!
zhbvssong
谁折腾
gbluo324
原文由 zhbvssong(zhbvssong) 发表:
好惨呀,如何能避免呢?
如果第一次被拒,更换其他杂志再投稿时,不要再选择原来的审稿人,有的杂志还有回避审稿人的选项,可以将原来的审稿人列为黑名单。
审稿人的选择原则,一般尽量找熟悉的专家。另外最简单的办法就是从自己文章后面参考文献里面找通讯作者。
