参考
Analysis of PEG 400 in perfusate samples by aqueous normal phase (ANP) chromatography with evaporative light scattering detection
Gregory K. Webster, Ashley Elliott, Arik Dahan and Jonathan M. Miller
Anal. Methods, 2011, 3, 742-744
A rapid method for the analysis of polyethylene glycol (PEG 400) in perfusate samples is presented. Because PEG 400 lacks a strong chromophore in the UV range, detection was accomplished using evaporative light scattering detection (ELSD). In order to optimize the ELSD signal performance for a volatile mobile phase, the chromatographic separation was optimized using aqueous normal phase conditions on a Cogent® Diamond Hydride column.
