在一些英文资料中,看到了fluorescer一次,请问这个词是什么意思?是代表的靶材吗? 上下文环境 In general the elements analyzed by the Gd fluorescer have higher detection limits than the other fluorescers (see Table 2). The reason for this is due to limitations in the upper voltage limit of the x-ray tube power supply and the use of rhodium instead of a heavier element such as tungsten as a target material for the x-ray tube. As a secondary consequence of this, there are also higher detection limits for many of the elements below chromium because they overlap the elements analyzed by Gd.
