主题:【讨论】红外光谱仪附件秀。
浏览0 回复33 电梯直达
tangtang
红外光谱仪都有哪些附件呢?
这些附件都有什么用途呢?
欢迎讨论。
tangtang
提供自拍图片的,加五分,每人加十分为限。
提供网络图片加1分。无法判断来源的加1分。
悠旸
见到过一个ATR附件用带透镜的压杆,右侧的透镜像个放大镜,便于观察样品状况。
该帖子作者被版主 tangtang5积分, 2经验,加分理由:5分到手了
悠旸
再来张俯视图。
该帖子作者被版主 tangtang5积分, 2经验,加分理由:5分又有了。
tangtang
原文由 悠旸(ihqs) 发表:
带透镜的ATR附件,是不是比较少见?
悠旸
我只见过一个,就是压杆带透镜,可以观察压紧样品的状态。
原文由 tangtang(tangtang) 发表:
原文由 悠旸(ihqs) 发表:
带透镜的ATR附件,是不是比较少见?
happyalife
衰减全反射(ATR)附件
  Smart DuraSamplIR Diamond ATR Accessory
  Smart MIRacle ATR Accessory
The Smart MIRacle is ideal for users on a limited budget who handle a variety of
sample types. The single crystal plate covers experiments that require different
spectral ranges. Features:• economic • versatile - solid and liquid sampling
possible• horizontal sampling surface - obtain high quality infrared spectra
without sample preparation.
  Smart Golden Gate Diamond ATR Accessory
Featuring a type IIa diamond, the accessory is fast, sensitive and robust.  Due
to its rugged design, it can be used for almost any sample type in research or
quality assurance/control environments. The accessory is useful for:•  polymer
pellets• intractable, opaque solids• single fibers• corrosive
liquids•
geochemical samples• powders• coated wires• air sensitive samples
  Smart DuraScope Micro-ATR Accessory
With all of the advantages of traditional ATR sampling, this tool also provides
the unique ability to simultaneously image and analyze your sample. Features:•
video enhancement - an integrated video monitor and PC video card • sample
handling on upper-surface of micro-ATR• innovative pressure device •
versatility
- ideal for all sample types
  Smart SplitPea
This accessory is configured to apply localized, known pressure to produce
superior contact between the sample and the internal reflection element. Sample
types include: • hard samples - combinatorial chemistry crowns• small samples -
individual fibers • large samples - transparency film
  Smart Orbit Accessory
The Smart Orbit accessory is a high-performance diamond single-bounce ATR
accessory.  This accessory offers users the many advantages of diamond ATR
technology including the ability to analyze hard, abrasive, or caustic
materials.  It uses a real Type IIA diamond for ruggedness and versatility.
  Replacement crystals, supplies and options for ATR
The base optical units for the Baseline Series, the Gemini Dual HATR/Diffuse
Reflectance, Single-Bounce HATR and Multi-Bounce HATR accessories are no longer
offered by Thermo. Replacement crystals, supplies and some options are still
available. This product is no longer offered by Thermo
  Spectra-Tech Foundation Performer
The Spectra-TechTM Foundation Performer makes changing from one crystal to
another quick and hassle-free and protects the optics from coming in contact
with the sample. This makes the accessory a good choice for liquid analysis,
particularly samples with high viscosity or those that can harm optical
components.Applications:• Single polymer beads• Polymer films• Pastes and
gels•
Liquids• Powders
  Smart Performer
This ATR accessory's wide selection of easy-to-change crystal choices (ZnSe, Ge,
Si and AMTIR) permits analysis of all types of samples ranging in size, shape,
texture and pH. The small spot size of 2mm makes sampling positioning and
experimental analysis easy.
  Research-Grade Vertical Variable Angle ATR
  Model 300 Series
  HATR Flow Cells for Spectra-Tech ARK
The HATR Flow Cell for Spectra-Tech TM ARK extends the versatility of the ARK by
allowing dynamic studies of aqueous and nonaqueous liquids, while the Heated
HATR Flow Cell allows thermo dynamic studies of these liquids offering a unique
capability for samples to be analyzed at elevated temperature and pressure.
  Thermal Trough Plates for Spectra-Tech ARK
Offering heat-resistant handles and a Teflon-coated aluminum plate enabling safe
handling, the Thermal Trough Plates make crystal removal and replacement easy.
  Spectra-Tech ARK Trough and Flat Plates
A patented crystal design ensures high-energy throughput and reproducibility
without the need for optical alignment when changing samples and sample plates,
therefore the cell will not leak and crystal damage is minimized.
15. 附件: Smart OMNI进样器
16. Smart Endurance
智能金刚石单次反射ATR分析附件Smart Endurance
17. Smart Multi-Bounce HATR
This accessory is ideal for rapid quantitative and qualitative analyses, since
sample preparation is generally not necessary - reducing analysis time and the
risk of sample contamination.
Applications:
• Liquids
• Pastes and gels
• Powders
• Films
• Coatings on flat samples
18. Smart SpeculATR
This accessory combines the diverse sampling power of ATR with the specialized
sampling of specular reflectance. A cost-effective solution for labs that
analyze strongly absorbing samples, or that would benefit from a multi-technique
approach to sampling.
19. Thermal HATR Cells for ARK
The ARK is available with a Thermal configuration.  For those who already own an
ARK Kit a Thermal Upgrade Package is available.
20. Spectra-Tech Foundation Endurance
Very little material is required to sample with the Spectra-Tech Foundation
Endurance. Cleanup is simple and total analysis time, including sample loading,
and analysis is less than two minutes. The Spectra-Tech Foundation Endurance
diamond offers the ultimate in chemical resistivity.
21. Spectra-Tech Foundation Multi-Bounce HATR
The design of the Spectra-TechTM Foundation Multi-Bounce HATR facilitates choice
of pathlength by simply changing crystal materials. Three crystal choices (ZnSe,
Ge and Si) are available to handle a wide range of applications.
22. Smart ARK
  Smart ARK 是研究和分析测量实验室的理想选择。由于无需进行样品制备,Smart ARK
  非常适合准确的定量、定性分析。其高性能得益于获得专利的独特晶体设计和高光学收集效率。在分
析需要高灵敏度的低浓度样品时,多次反射晶体的效果也非常好。Smart
  ARK 适用于多种晶体和角度,具有加热和流通选项,功能非常广泛,可满足众多分析需求。
  Thermo Scientific Smart ARK 是一款稳定、耐用的高能多次反射型HATR。
    采用获得专利的晶体设计,可快速转换晶体板,无需重新校准光束
    晶体板有槽形和平板形两种,可以满足特定样品分析需求:槽形晶体板  适用于液体、糊状物和胶
类物,平板晶体板适用于固态膜
    晶体板涂有聚四氟乙烯,可以改善耐化学性,防止板表面褪色
    压力器件已经过优化,可以减少晶体因压力太大或不均而出现的破裂情况
    晶体设计可以确保各次测量的重现性和可靠性,在使用多个光谱仪的实验室间转换分析方法时,此
特性非常重要
    晶体板可以提供合适的角度和材料,产生0.6 微米至45 微米的有效光程长度
    晶体材料几乎适用于所有pH 范围的样品
  Thermal Option
    样品可加热到的温度范围:环境温度至100°C,精确度:±1° C
    包括一套不导热手柄,安装于槽形采样板
    隔热型,将辐射到样品室的热量降至最低
23. Spectra-Tech Foundation Thunderdome
该帖子作者被版主 tangtang2积分, 2经验,加分理由:没图就2分
happyalife
漫反射附件
  Ambient Chamber for Collector and Collector II
The Ambient Chamber accessory has a unique design that permits a dome/sample cup
assembly to be removed from the Spectra-TechTM  CollectorTM or Collector IITM
and loaded in a glove box with a prepared sample.
Features:
• Removable dome/sample cup
• Easily attached to the Collector I, II
• Expands the applications of diffuse reflectance
  Si-Carb Sample Prep Kit
  高温/高压/真空室
  Temp/Vacuum Chamber for Collector
The Temperature/Vacuum Chamber is ideal for experiments requiring high
temperatures and vacuum conditions.
  Environmental Chambers for Smart Collector
While still taking advantage of the Smart Collector's compound parabolic
concentrator (CPC) optical design, this enables experiments to be conducted in:
• Inert gaseous environments  • Heats up to 900°C  • Pressures from
ambient
to 1000 psi and 10-5  Torr
  Smart Collector
Designed for analysis of solid samples, it's most beneficial to users in
analytical test laboratories where fast sample turnaround and rigorous
reproducibility are necessities. This accessory can perform a wide variety of
diffuse reflectance experiments quickly and easily at elevated temperatures,
high pressure and/or vacuum conditions.
  Smart Diffuse Reflectance
Maximizes diffuse scattered radiation, while minimizing specular reflected
radiation. The tool allows samples to be analyzed as is, with a slight amount of
grinding and/or mixing with potassium bromide (KBr). Diffuse reflectance
provides non-destructive analysis for a wide variety of samples.
  Spectra-Tech Foundation CPC Diffuse
The Spectra-TechTM Foundation CPC Diffuse makes diffuse reflectance analysis
easy and reliable. The CPC makes it possible to obtain improved results from
samples that would be difficult on older optical designs and offers easy sample
preparation.
Applications:
• Powders
• Organics
• Intractable solids
  Spectra-Tech Collector II*漫反射附件
Spectra-Tech Collector II 是用于漫反射红外分析的最先进多功能附件之一。它能够满足下列实验室
的需求:样品流通量和重复性要求高的QA/QC
实验室、需要多功能采样附件的研发实验室。
    Thermo Scientific Spectra-Tech Collector II 漫反射附件适合对粉末样品进行高灵敏度分析和
环境研究。
(1)Advantages
A.光学器件耐用、流通量高,在进行粉末分析时,具有高灵敏度
B.获得专利的Blocker 器械可以去除镜面反射能量,防止漫反射光谱变形
C.集成式吹气装置可以消除光谱数据中来自二氧化碳和水的大气干扰
D.便捷、可重复的样品加载功能和光学器件保护功能
(2)Environmental Chambers
A.可精确控制样品环境
B.可以获得各项条件,如:升温或升降压、非周围气体环境和周围环境
C.高温/高压仓或高温/真空仓可以实现各类研究,如:多相催化机理、热降解、沸石分析和危险环境研
D.反应监测
E.催化测量
F.聚合物
(3)Spectra-Tech Si-Carb Sample Prep Kit
扩展了样品分析范围(不仅包括粉末样品和小型固体样本)
包括摩擦样品所用的碳化硅盘
可以获得粘附于盘面的材料的红外光谱
  Smart Near-IR UpDRIFT
This is a top-loading diffuse reflectance accessory for the near-infrared
spectral region.  The UpDRIFTTM uses a unique optical focusing system known as
CPC (compound parabolic concentrator) that virtually eliminates the specularly
reflected component, which distorts spectral results.
该帖子作者被版主 tangtang2积分, 2经验,加分理由:一个附件2分
happyalife
红外附件
  热重-红外(TGA-IR)联用接口
热重-红外(TGA-IR)接口为 Nicolet FT-IR光谱仪设计,
在热重分析的过程中,实时用红外光谱仪对被加热样品分解和挥发所逸出的气体进行监控及准确鉴别
特殊设计的流动池在保证足够的红外光通量的同时,消除内壁残留物对红外谱图造成影响,并在气体流
量很大时保持高稳定性,且可以极方便地从接口中拆卸、清洗
  热重/ 红外接口设计灵活,可以被放置在红外光谱仪的主样品仓中,也可以联接在红外光谱仪的左侧
或者右侧,使用者可以根据需要灵活配置
  加热传输线采用特殊气体惰性材料,保证逸出气体在进入流动池的过程中气体组分不与其发生反应
  Series 数据采集软件可以实时显示重建谱图及红外谱图,使用者可以根据红外谱图判断TGA分析中逸
出气体的成分
  联机信噪比:优于4.310-5Abs,即10,000:1(测量条件:峰-峰比,8cm-1 光谱分辨率,30 秒扫描,
KBr 分束器,DTGS
  检测器,光管温度为200℃,采用样品仓接口)
2. Nicolet FT-IR的AEM模块
3. 气相-红外(gc-IR)联用接口
适用于Nicolet FT-IR 光谱仪的gc-IR Interface 兼具气相色谱分离能力和傅立叶变换红外光谱(FT-IR)
特定鉴定能力。结合OMNIC
Series 软件使用时,gc-IR Interface 的灵敏度和性能极高,易于使用。将gc-IR Interface 和Thermo
Scientific
Nicolet FT-IR 光谱仪结合使用时,可高效分析多成分有机样品,包括溶剂、反应剂、药品、石化产品
和环境样品。
  适用于Nicolet FT-IR 光谱仪的Thermo Scientific gc-IR Interface 性能极高、易于使用,是gc-
IR
分离和鉴定的理想选择。
gc-IR Interface 非常适合分析高分辨率毛细管柱内的小洗脱体积样品。在易挥发物品的低毫克范围内
,系统通常会达到极高灵敏度。
(1)Advantages
A.可直接将毛细管柱插入光导管,以避免传输管线内出现成分降解和峰加宽情况
B.镀金光导管光程长、内径小,可确保低毫克灵敏度的红外光谱响应实现最大化
C.系统无与伦比的灵敏度和可靠性得益于获得专利的MCT-A 检测器
D.通过对针定位的Smart 检测器可以与台式检测器互换,无需进行校准
E.Smart 检测器具有即插即用功能,可以立即识别检测器及其位置
F.Smart 检测器配有专利装置,可以防止检测器元件上结冰,使液体保留时间达到18 小时
(2)Omnic Series Software
A.gc-IR Interface 使用基于Windows*的OMNIC Series 软件进行数据收集和操作,通过简便的OMNIC 软
件界面集成了执行高级gc
操作所需的功能和控件
B.软件采用图形用户界面和点击式操作方式,非常直观
C.在收集数据时,可以实时显示Gram-Schmidt 重建图、(IR 色谱图)官能团色谱图和红外光谱图
D.数据存储为多个文件,因此,可以使用一个软件命令来集中处理所有数据
E.通过使用各种可用气相谱库,可以提取单谱或拼接谱图,以便进行化合物鉴定
F.可以对gc 数据进行二维轮廓和三维瀑布显示,增强了复杂样品混合物的处理能力
  Specifications
  Optics and Hardware
  Baseplate:精密铸造的底板通过锁定管线方式连接至Nicolet FT-IR 光谱仪的右侧或左侧,实现gc-IR
Interface 的精确光学校准
  Optics: 高效的光学设计:利用三面反射镜来引导来自光谱仪的准直束,使其通过镀金光导管,进入
位于gc-IR Interface 的MCT-A 检测器
  Lightpipe:镀金玻璃流通池配有镀金合金端盖;光导管密封件由高温聚合物制成,可以在325℃的温度
下连续工作;低死体积设计(长度:15cm,内径:1.0mm)可以使吸收率达到最高,同时大大减小峰加宽
情况
  Transfer Lines: 不锈钢、玻璃衬里、绝热;可直接插入气相层析柱,为层析组分进入镀金光导管提
供了一个相当稳定的通道
  Make-up Gas: gc
  烘箱新增可调试尾吹气控制器,可保持光导管内的线速度和层析峰的完整性;尾吹气在柱外围流动,
引导柱流出物通过光导管;标准流速:0.20mL/min
  Temperature Control:数字固态温度控制器可单独控制光导管和传输管线温度;软件可选择温度范围
:环境温度至325
  ℃Detector:不锈钢;建议:高灵敏度MCT-A(范围:11,700 to 600cm-1); 可选:MCT-B(范围:
11,700 to
  400cm-1); 智能设计,具有即插即用功能,可与光谱仪上的检测器位置互换,无需进行校准;配有专
利装置,可防止检测器元件上结冰,使液氮保留时间达到18
  小时
  Performance Characteristics
  Scan Speed: 在  8cm-1 光谱分辨率下,可以收集、共同添加至7 次扫描,可以在不到1 秒的时间内
处理、显示实时IR 光谱和IR
  色谱,并将其存储至硬盘(计算机的最低配置应为:400 MHz Pentium*)可从双面干涉图生成光谱,
达到最高信噪比
  Peak-to-Peak Noise:不到1.0 x 10-4 Abs. 用4 秒收集时间,通过KBr 光束分离器、MCT-A 检测器和
200
  ℃光导管,可以测得8cm-1 分辨率时的峰间噪声
  gc Oven Compatibility:TRACE gc Ultra 烘箱接口;关于与其他色谱柱箱的兼容性,请咨询Thermo
Scientific 。
该帖子作者被版主 tangtang2积分, 2经验,加分理由:还有吗,继续2分,分数多得很。
happyalife
4. SPR 100 Module
The SPRTM 100 module from Thermo provides life science, pharmaceutical and food
science research laboratories with high sensitivity, high dynamic range and fast
measurement time. In addition, the module enhances the quantitative
characterization of biomolecular interactions including those involving DNA,
RNA, protein and carbohydrates.
5. Smart NIR Integrating Sphere
提供了分析漫反射的最佳方法。与传统方法相比,此进样模块分析固体和粉末的工作量更高、优势更大
。非常适合鉴定原材料、测定成分,可以通过玻璃或其它包装材料进行进样。Smart
NIR Integrating Sphere 简化了样品处理程序,增加了样品流通量。
    Thermo Scientific Smart NIR Integrating Sphere 可以改善Thermo Scientific
Nicolet* FT-IR 光谱仪的近红外能力。
6. 光弹调制联机模块(PEM)
光弹调制(PEM) 模块适用于Nicolet Series FT-IR
光谱仪。光谱仪具有双通道功能,可以同时采集要求苛刻的偏振调制实验的积分信号和差分信号。模块
的整体设计允许研究人员通过微小的校准调整,便可分析反射面上的薄膜。
    适用于Nicolet FT-IR 光谱仪的Thermo Scientific PEM 模块是偏振调制(PM) 实验专用的外部实验
模块。
7. Spectra-Tech ARK
Spectra-Tech ARK 是一款极稳定、耐用的高灵敏度水平衰减全反射(ATR) 附件,可用于傅立叶变换红外
(FT-IR)
光谱仪。Spectra-Tech ARK 采用优化的多次反射HATR 技术,可以对各种样品进行定量、定性分析。
Thermo Scientific Spectra-Tech ARK 非常适合需要便捷处理样品和高灵敏度的质量控制或研究实验室
8. 适用于Nicolet*FT-IR 光谱仪的辅助实验模块
适用于Nicolet FT-IR 光谱仪的辅助实验模块(AEM)
非常适合始终进行一类实验,但是仍有进样灵活性需求的实验室。该模块增加了一个样品室,该配置与
Nicolet FT-IR 光谱仪中的相同,提高了实验灵活性。
适用于Nicolet FT-IR 光谱仪的Thermo Scientific 辅助实验模块提供了第二个样品室,增强了实验能
力。
  Module Features
  构建于精密铸造的底板上,对针定位适合所有光学部件
  单块棱形转动镜通过销钉固定于底板上的相应位置,实现永久稳定性,无需再进行校准
  标准  Monoflect*双检测器光学器件具有计算机化选项(前部或后部检测器位置)
  可以在主光谱仪和AEM 检测器位置间互换Nicolet FT-IR 精密的预先校准检测器,无需再重新校准
  辅助吹气端口增加了吹气灵活性
  独特的Smart Purge*选项可以在更换样品时快速恢复吹气
  密封式脱水光学器件选件可实现灵活的无吹气操作
  Accessory Option
  大型附件或长期实验所接附件(如长光程气池、TGA-IR interface)非常适合配有AEM 的Nicolet FT
-IR
  系统。通过将附件永久安装在AEM 样品室,可以将AEM 专用于特定进样技术,以便光谱仪样品室可以
进行更多灵活进样。
  大样品室适用于智能型Smart Accessories*,可以自动进行识别、缩短制备时间
  此外,还可容纳任何标准的底板安装式进样附件
  附件完全可以在AEM 和光谱仪样品室之间互换
  AEM Optics
  Baseplate:精密铸造的Stabilizer*底板带有预先校准的销钉固定位置,适用于左侧或右侧光学配置及
样品室底板
  Cover:独立装置包括右侧或左侧光束孔道和标准吹气快门;闩锁式样品室盖板
  System Purge/Seal:  样品室吹气端口和附件;吹气和/或密封、脱水配置;可选Smart Purge 恢复系
  Mirror Optics: 专有单块棱形转动镜通过销钉固定于相应位置
  Sample Compartment:大样品室(长:21cm,宽:× 26cm,高:×
  18cm);以销钉固定的全尺寸底板和E.S.P. 辨识晶片可以接受传统E.S.P. 和Smart
  附件;双槽、高度可调的玻片样品架;样品室检测器输入、控制总线和两个辅助接头,实现自动附件
控制
  Detector Optics: 标准Monoflect 计算机化双前部、后部内部检测器位置;预先校准、以销钉固定的
位置,便于轻松交换检测器,
  无需再进行校准;统一校准的检测器,可以在AEM 和主要系统位置间自由互换,无需再重新进行校准
  Detectors:
    DLaTGS/KBr (12500 to 350cm-1)
    DLaTGS/Csl (6400 to 200cm-1)
    Silicon (25000 to 8600cm-1)
    PbSe (13000 to 2000cm-1)
    InSb (11500 to 1850cm-1)
    MCT-A (11700 to 600cm-1)
    MCT-B (11700 to 400cm-1)
    DLaTGS/PE (700 to 50cm-1)
Mounting:专有Lock-in-Line&asterisk; 光谱仪连接方式,提供以销钉固定的永久性校准位置;可配置
到光谱仪右侧或左侧
AEM 兼容所有Nicolet FT-IR、Nicolet Nexus*、Magna-IR* 和Protg*光谱仪。它也可以结合Thermo
Scientific 外部进样设备使用,如:GC Interface、Nicolet Continuμm* IR  显微光谱仪、PEM 与
FT-Raman
模块。
9. Smart iTR
Smart iTR 是一款性能超高的多功能型衰减全反射法(ATR) 采样附件。Smart iTR
主要用于单次反射金刚石晶体,另外还可提供其它选件,实现完整配置。它可以实现极高的灵敏度和IR
流通量。
    Thermo Scientific Smart iTR 可实现出色的流通量,无需进行样品制备。
  非常适合分析固体、液体、糊状物和胶类物
  可使用各种晶体,满足不同采样需求
  单次反射晶体用于常规的材料鉴定目的
  三次反射晶体选件可以增加灵敏度
  在分析反光材料上面的涂层时,镜面板可以实现极高的灵活性
  晶体板通过快速释放装置固定于相应位置,可轻松取出,以进行清洁或更换,可反复插入,无需进行
校准
  ATR 晶体板后部有硒化锌聚焦光学器件,可实现极佳性能
  大型顶板可容纳大部分样品
  Teflon* 涂层板可轻松抬离,进行简便清洁
  加工精密,配有无反应垫圈,因此,顶板和晶体护罩之间结合紧密,无需担心喷溅
  校准后的高压钳可施加最高10,000 psi 的压力,配有可互换端头,以用于坚硬、柔软或丸片形样本
  Smart iTR 附件包括三种固定于不锈钢件中的常用ATR 晶体(标准配置):金刚石、硒化锌和锗。每
种晶体在特定环境下的性能都非常出色。
    Diamond ATR Crystal
    Features
    稳定、功能强大,非常适合分析坚硬的、研磨性、反应性或腐蚀性材料
    多功能ATR 在1000cm-1时,穿入深度可达2µm以上,可用于多种样品
    保修期为五年
    可验证配置
    损失——本征吸收范围:230cm 至1800cm-1
    Specifications
    截止低波数:650cm-1 (因硒化锌透镜)
    穿透深度:2.03µm(1000cm-1 时)
    折射率:2.4
    有效pH 范围:1 至14(硒化锌5- 9)
    入射角:42°
    ZnSe ATR Crystal
    Features
    对于常规分析,大部分常用ATR 晶体的性能都非常优异,且成本低
    流通量和穿透深度与金刚石相近
    可用于多种样品,但是较软,不像其它晶体那样具有化学性惰性
    随着时间的推移,可能会受酸性物质腐蚀,被坚硬样品刮擦,从而降低灵敏度
    可验证配置
Specifications
截止低波数:650cm-1
•穿透深度:2.03µm(1000cm-1 时)
•折射率:2.4
•有效pH 范围:5 至9
•入射角:42°
  Germanium ATR Crystal
  Features
  坚硬、稳定(尽管不像钻石那样优异),折射率高
  穿透深度很浅,非常适合高吸收或高散射样品,如含橡胶的炭黑
  在中红外范围,性能出色,透射比可上升50%
  使用范围有限,但是耐化学性良好,无论是对于酸性物质还是碱性物质
Specifications
截止低波数:700cm
穿透深度:0.67µm(1000cm-1)
折射率:4.0
有效pH 范围:1 至14
入射角:42°
  Silicon ATR Crystal
  Features
  坚硬,折射率高
  适合强吸收剂或研磨性样品
  由于可以承受热冲击,因此非常适合温度研究
Specifications
截止低波数:700cm-1
•穿透深度:0.84µm at 1000cm-1
•折射率:3.4
•有效pH 范围:1 至12
•入射角:42°
Smart iTR 附件兼容Thermo Scientific Nicolet* iS*10 FT-IR 光谱仪、Thermo Scientific
Nicolet iZ* 10
辅助模块和Thermo Scientific Nicolet 6700、Nicolet 8700 FT-IR 光谱仪。
该帖子作者被版主 tangtang2积分, 2经验,加分理由:加2分再说。
happyalife
智能型多次反射式HATR
  智能型多次反射式HATR 非常适合获取高质量的红外光谱,无需进行样品制备。由于通常不需要进行样
品制备,因此Thermo Scientific
  智能型多次反射式HATR 是快速定量、定性分析的理想选择。
  智能型多次反射式HATR 的晶体尺寸、容积小,却可以实现单次反射附件无法实现的高灵敏度。智能型
多次反射式HATR
  的有效光程长度为10.1μm,非常适合提供材料表面的特性信息。
  水平采样表面非常适合获取高质量的红外光谱,无需进行样品制备。
  多次反射式HATR 护盖内的储存空间可轻松容纳采样工具
  晶体装于板上,固定于相应位置,更换时只需抬离一个晶体,放入另一个晶体。
  板面涂有Teflon,可以提高耐化学性,防止褪色。
  您可以擦净晶体,也可以抬离整块板,进行清洁。
  Multi-Bounce HATR Trough Plate Kit
适合分析液体、粉末、糊状物和胶类物
ATR 晶体嵌入式安装于槽形防泄露采样板。
ATR 晶体样品板可以限制会损坏附件的灾难性液体喷溅情况发生。
挥发性液体护盖可避免溶剂蒸发。
粉末按压装置可确保粉末状样品和晶体完整接触。
  Multi-Bounce HATR Flat Plate Kit
适用于分析扁平样品上的薄膜和涂层
配置方式为:晶体与板表面齐平
包括一个压力装置,该装置可提供可再生压力,确保样品和晶体之间的光学接触一致。
  Multi-Bounce HATR Combination Plate Kit
  在需要分析各种液体和固体样本时,此器械是一项理想选择。
  包括:
  槽形板
  平板
  挥发性液体护盖
  粉末按压装置
  压力装置
  Specifications
  Crystal Material
  硒化锌(标准配置)(4000cm 至650cm-1)
  锗(可选)(4000cm 至800cm-1)
  硅(可选)(4000cm 至1500cm-1)
  Number of Reflections:10
  Crystal Angle: 45°
  Pathlength:大约10 微米
  Sample Volume (trough):0.5 毫米
镜反射附件
1. Smart Refractor
This accessory is ideal for very thin layers or coatings on reflective
substrates - its high angle of incidence and built in polarization provide high
sensitivity. Examples of such samples are thin films on metal and semiconductor
substrates and laboratory and quality control applications.Features:• broad,
horizontal sampling surface for high sample throughput• fixed 75 degree incident
angle• built-in, removable polarizer and two wedged ZnSe windows
  VeeMax Variable Angle Specular Reflectance Accy
By providing angles of incidence that can be continuously varied by moving a
single control, this accessory is ideal for specular reflection measurements of
films and coatings on metallic surfaces. Three masks are included to allow
analyses of small samples or isolating areas on larger samples. An optional
polarizer can be mounted on the accessory as a sensitivity enhancement required
for the analysis of thin films by grazing angles.
  FT-30 Fixed 30° Specular Reflectance Accessory
  Spectra-Tech IR Polarizer
Manufactured using a holographic/photolithographic technique, the polarizer
includes a 360° rotary holder calibrated with 2° scale divisions. It can be used
in any universal slide mount.
  Spectra-Tech Model 500 Series
The Spectra-TechTM Model 500 Series is a vertical variable angle accessory,
versatile for most reflectance measurements as its angle can be varied from near
normal incidence to near grazing angle incidence. Applications:? Specular
reflection measurements of films and coatings on metallic surfaces
  Smart SAGA
  Smart
  SAGA(高光带孔掠射角)极易操作,性能优异,样品区辨识能力极高。只需将样品平放在水平采样台
上,用激光雕刻隔栅进行定位,如需要则转动转轮以设置孔尺寸,然后扫描。
  掠射角反射系数是用以分析薄涂层或沉淀物的选择性方法,因为高入射角可以增大穿过感兴趣材料的
红外光束的光程长度,从而大大改善灵敏度。由于高入射角和选择性偏极化,因此可获取单层灵敏度。
  Thermo Scientific Smart SAGA 适用于对金属基上的亚微米薄膜进行掠入射分析。
  Spectra-Tech Foundation SpeculATR
The Foundation SpeculATR provides routine single-reflection ATR spectroscopy and
fixed-angle specular reflectance for ensured repeatability. Delivering
calibrated pressure for good sample-to-crystal contact during ATR measurements
this accessory is ideal for many applications
  FT-80 Fixed 80° Grazing Angle Accessory
该帖子作者被版主 tangtang2积分, 2经验,加分理由:谈谈应用吧,不止加2分。
