原文由 木有才(xgy2005) 发表:原文由 sepujiance(raotao2) 发表:原文由 木有才(xgy2005) 发表:
麻痹性毒素我们以前都是用鼠生物法做的,是不是柱子不合适呢?
恩,很有可能,改用HILIC柱,分离效果就好很多了。但是不清楚为什么氨基柱不保留。
还是化合物极性问题
Column | Cogent Diamond Hydride™, 4µm, 100A | ||||||||||||
Catalog No. | 70000-15P-2 | ||||||||||||
Dimensions | 2.1 x 150 mm | ||||||||||||
Solvents |
Gradient |
Post Time | 5 min | ||||||||||||
Injection Vol. | 1 microL | ||||||||||||
Flow rate | 0.4 mL/min. | ||||||||||||
Detection | ESI - POS - Agilent 6210 MSD TOF MS | ||||||||||||
Samples | Samples from Dr. R.Kudela, Univ. of Calif., Santa Cruz, Dept. of Marine Sciences. Samples were injected as received. | ||||||||||||
Peak | Domoic acid 312.1442 m/z (M+H)+ | ||||||||||||
t0 | 0.9 min |
原文由 kylabs(kylabs) 发表:原文由 木有才(xgy2005) 发表:原文由 sepujiance(raotao2) 发表:原文由 木有才(xgy2005) 发表:
还是化合物极性问题
是的,还可以用Cogent Diamond Hydride亲水柱试试,也是用来分离极性物质的。
海产品中的软骨藻酸Domoic acid LCMS检测。
Method Conditions
Column Cogent Diamond Hydride™, 4µm, 100A Catalog No. 70000-15P-2 Dimensions 2.1 x 150 mm Solvents
A: 50% MeOH/ 50% DI H2O/ 0.1% formic acid B: Acetonitrile/ 0.1% formic acid Gradient
time (min.) %B time (min.) %B 0 95 8 30 7 30 10 95 Post Time 5 min Injection Vol. 1 microL Flow rate 0.4 mL/min. Detection ESI - POS - Agilent 6210 MSD TOF MS Samples Samples from Dr. R.Kudela, Univ. of Calif., Santa Cruz,
Dept. of Marine Sciences. Samples were injected as received.Peak Domoic acid 312.1442 m/z (M+H)+ t0 0.9 min
原文由 sepujiance(raotao2) 发表:原文由 kylabs(kylabs) 发表:原文由 木有才(xgy2005) 发表:原文由 sepujiance(raotao2) 发表:原文由 木有才(xgy2005) 发表:
还是化合物极性问题
Method Conditions
