主题:【分享】USP色谱柱规格对照(固定相)
yifan1117
(根据Based on USP32/Reagents/Solutions/Chramotograph reagents)
Phases 相
G1
Dimethylpolysiloxane oil.
二甲基聚硅氧烷油
G2
Dimethylpolysiloxane gum.
二甲基聚硅氧烷胶
G3
50% Phenyl-50% methylpolysiloxane.
50%苯基-50%甲基聚硅氧烷
G4
Diethylene glycol succinate polyester.
聚丁二酸乙二醇酯
G5
3-Cyanopropylpolysiloxane.
3-氰丙基聚氧硅烷
G6
Trifluoropropylmethylpolysiloxane.
三氟丙基甲基聚硅氧烷
G7
50% 3-Cyanopropyl-50% phenylmethylsilicone.
50%-3-氰丙基-50%苯甲基硅氧烷
G8
80% Bis(3-cyanopropyl)-20% 3-cyanopropylphenylpoly- siloxane
(percentages refer to molar substitution).
80%双(3-氰基丙基)-20%3-氰丙基苯聚硅氧烷(百分比参见分子取代度)
G9
Methylvinylpolysiloxane.
甲基乙烯基聚硅氧烷
G10
Polyamide formed by reacting a C36 dicarboxylic acid with 1,3-di-4-piperidylpropane and piperidine in the respective mole ratios of 1.00:0.90:0.20.
聚酰胺,由C36 二羧酸和1,3-二-4-哌啶基丙烷和哌啶以摩尔比1.00:0.90:0.20反应而得
G11
Bis(2-ethylhexyl) sebacate polyester.
双(2乙基己基)癸二酸聚酯
G12
Phenyldiethanolamine succinate polyester.
苯基二乙醇胺琥珀酸聚酯
G13
Sorbitol.
山梨醇
G14
Polyethylene glycol (av. mol. wt. of 950 to 1050).
聚乙二醇(平均分子量950-1,050)
G15
Polyethylene glycol (av. mol. wt. of 3000 to 3700).
聚乙二醇(平均分子量3,000~3,700)
G16
Polyethylene glycol compound (av. mol. wt. about 15,000). A high molecular weight compound of polyethylene glycol with a diepoxide linker.
[note—Available commercially as Polyethylene Glycol Compound 20M, or as Carbowax 20M, from suppliers of chromatographic reagents.]
聚乙二醇(平均分子量3,000~3,700) 。聚乙二醇与一种二环氧化物粘合物的高分子合物。[注----商名聚乙二醇合物20M,或Carbowax 20M,色谱试剂商处购得]
G17
75% Phenyl-25% methylpolysiloxane.
75%苯基-25%甲基聚硅氧烷
G18
Polyalkylene glycol.
聚亚烷基二醇
G19
25% Phenyl-25% cyanopropyl-50% methylsilicone.
25%苯基-25%氰丙基-50%甲基硅氧烷
G20
Polyethylene glycol (av. mol. wt. of 380 to 420).
聚乙二醇(平均分子量380~420)
G21
Neopentyl glycol succinate.
丁二酸新戊二醇酯(NGS)
G22
Bis(2-ethylhexyl) phthalate.
双(2-乙基己基)邻苯二甲酸酯
G23
Polyethylene glycol adipate.
聚己二酸乙二醇酯 EGA
G24
Diisodecyl phthalate.
二异癸邻苯二甲酸酯
G25
Polyethylene glycol compound TPA. A high molecular weight compound of a polyethylene glycol and a diepoxide that is esterified with terephthalic acid.
[note—Available commercially as Carbowax 20M-TPA from suppliers of chromatographic reagents.]
聚乙二醇TPA(Carbowax 20M对苯二甲酸)聚乙二醇和二环氧化物的高分子化合物用对苯二甲酸酯化
[注---商业名称:Carbowax 20M-TPA,色谱试剂供应商处可购]
G26
25% 2-Cyanoethyl-75% methylpolysiloxane.
25%2-氰基乙基-75%甲基聚硅氧烷
G27
5% Phenyl-95% methylpolysiloxane.
5%苯基-95%甲基聚硅氧烷
G28
25% Phenyl-75% methylpolysiloxane.
25%苯基-75%甲基聚硅氧烷
G29
3,3?-Thiodipropionitrile.
3,3’-硫代丙晴 TDPN
G30
Tetraethylene glycol dimethyl ether.
四甘醇二甲基醚
G31
Nonylphenoxypoly(ethyleneoxy)ethanol (av. ethyleneoxy chain length is 30); Nonoxynol 30.
壬基酚聚氧乙烯醚(平均乙烯氧基链长度30);壬苯醇醚30
G32
20% Phenylmethyl-80% dimethylpolysiloxane.
20%苯甲基-80%二甲基聚硅氧烷
G33
20% Carborane-80% methylsilicone.
20%碳硼烷-80%甲基硅
G34
Diethylene glycol succinate polyester stabilized with phosphoric acid.
聚乙二醇丁二酸酯,用磷酸固化
G35
A high molecular weight compound of a polyethylene glycol and a diepoxide that is esterified with nitroterephthalic acid.
聚乙二醇及硝基对苯二甲酸酯化双环氧化物高分子合物(用硝基对苯二甲酸酯化)
G36
1% Vinyl-5% phenylmethylpolysiloxane.
1%乙烯基-5%苯甲基聚硅氧烷
G37
Polyimide.
聚酰亚胺
G38
Phase G1 containing a small percentage of a tailing inhibitor.
[note—A suitable grade is available commercially as “SP2100/0.1% Carbowax 1500” from Supelco, Inc. (www.sigmaaldrich.com/supelco).]
G1固定相,加少量拖尾抑制剂
[注----适用级别,商名SP2100/0.1% Carbowax 1500’’厂商Supelco Inc.,网址www.sigmaaldrich.com/supelco]
G39
Polyethylene glycol (av. mol. wt. about 1500).
聚乙二醇(平均分子量1500)
G40
Ethylene glycol adipate.
己二酸乙二醇酯
G41
Phenylmethyldimethylsilicone
(10% phenyl-substituted).
苯甲基二四基聚硅氧烷
(10%苯取代)
G42
35% phenyl-65% dimethylpolysiloxane (percentages refer to molar substitution).
35%苯基-65%乙烯基硅烷
(百分比参见分子取代度)
G43
6% cyanopropylphenyl-94% dimethylpolysiloxane (percentages refer to molar substitution).
6%氰丙基苯-94%二甲基聚硅氧烷
(百分比参见分子取代度)
G44
2% low molecular weight petrolatum hydrocarbon grease and 1% solution of potassium hydroxide.
2%低分子量石油烃脂和1%氢氧化钾溶液
G45
Divinylbenzene-ethylene glycol-dimethylacrylate.
二乙烯基苯-乙二醇-二甲基丙烯酸酯
G46
14% Cyanopropylphenyl-86% methylpolysiloxane
14%-氰丙基苯基-86%-甲基聚硅氧烷
G47
Polyethylene glycol (av. mol. wt. of about 8000).
聚乙二醇(平均分子量8000)
G48
Highly polar, partially cross-linked cyanopolysiloxane.
强极性,部分交联氰基聚硅氧烷
dahua1981
