原文由 dahua1981(dahua1981) 发表:
Up to 950 C - Immune to EMI and Microwave
The OptoTemp 2000 was designed for reliable operation in the harshest chemical and electrical environments. This fiber optic thermometer is unaffected by microwave/RF radiation and plasma and can measure temperatures up to 950 C.
The OptoTemp 2000 features patented technology for a monolithic single-crystal temperature probe that eliminates the need for unreliable mechanical coupling. It measures temperature using the information derived from fluorescence decay.
Benefits
Immune to EMI, RF and microwave
Operates up to 950 C
Precise and reliable
Inert probe
Applications
Microwave/RF heating
Chemical processing
Molten metal measurements
Plasma processing
Semiconductor processing
OptoTemp 2000 Controller Specifications
Channels: Up to 4
Temperature range: 10 C to 950 C
Response time: 250 ms
Precision: +/- 1.0 C RMS over 8 samples
Accuracy: +/- 2.0 C
Power requirement: 90-260 VAC, 50-60 Hz
Power consumption: 5W @ 7.5 VDC
Output port: RS-232
Display: Back lighted LED
OptoTemp 2000 Probe Specifications
FLEX SUPER ULTRA
Temperature range: 10 C to 150 C 10 C to 400 C 10 C to 950 C
Connector type: ST ST SMA
Overall diameter: 2 mm 3 mm 3 cm*
Active probe length: 15 cm** 15 cm** 15 cm**
Protective sheath material PEEK Ceramic Ceramic
Item Code: OPTOTEMP-2000-FLEX OPTOTEMP-2000-SUPER OPTOTEMP-200-Ultra
Your Price: $2050 $2350 $2750
* A low thermal mass version with exposed 0.2 mm tip is also available
** Longer or shorter length available on custom probes
