【作者】 曾聪彦; 李依信; 梅全喜; 戴卫波; 钟希文;
【Author】 ZENG Cong-yan1,LI Yi-xin2,MEI Quan-xi1,DAI Wei-bo1,ZHONG Xi-wen1(1.Zhongshan Hospital,Guangzhou University of Chinese Medicial,Zhongshan 528400,China;2.Yunfu Drug Control Institute,Yunfu 527300,China)
【机构】 广州中医药大学附属中山中医院; 广东省云浮市药品检验所;
【摘要】 目的:建立布渣叶中山柰素的含量测定方法,为其制定质量标准提供依据。方法:采用高效
液相色谱法对布渣叶药材山柰素进行含量测定。色谱柱:Diamonsil(钻石)C18(250×4.6mm,5μm);流动相:甲醇-0.4%磷酸溶液(52∶48);流速:1.0mL/min;柱温:30℃;检测波长:367nm。结果:山柰素进样量在0.01021ug~0.20420ug范围内与峰面积呈良好的线性关系(r=0.9999)。平均加样回收率为99.13%,RSD为1.05%(n=6)。结论:所建立的方法简便、快捷,重现性好,可用于该药材的质量评价。 更多还原
【Abstract】 Objective:To establish the quantitative methods of kaempferol in Microcos paniculata and control its quanlity.Methods:The content of kaempferol in Microcos paniculata was determined by HPLC.The chromatgraphic conditions were as follows:Diamonsil C18(250×4.6mm,5μ),mobile phrase was methanol-0.4% phosphoric acid(52∶48),flow rate being 1.0ml/min,column temperature at 30℃,detection wavelength being 367nm.Results: Kaempferol showed a good linear relationship in the range of 0.01021ug~0.2042ug(r=0.999... 更多还原
【关键词】 布渣叶; 山柰素; 高效
液相色谱法;
【Key words】 Microcos paniculata; Kaempferol; HPLC;
