原文由 依风1986(xurunjiao5339) 发表:
附C-03标准.
4.2 Transfer the removed coating to a mortar and grind the sample with a pestle. An electric
grinder may be used when the sample is too difficult to grind with a pestle and a mortar.
Sieve the ground coating with a 500 :m sieve. The sample passing the 500 :m is then
sieve through a 250 :m. The portion of the ground coating that passes the 500 :m and
do not pass the 250 :m is used for the test. Place the portion in a weighing vessel and
dry to constant weight (to the nearest 1 mg) in an air convection oven at 60OC for 1 hour
Remove the vessel from the oven and cool in a desiccator.
4.3 Accurately transfer 100 mg of the dried coating into a tared 100 mL beaker and weigh to
the nearest 0.1 mg. Add 20 mL of the 5% (v/v) HCl leaching solution and immediately
start stirring for 10 ±1 min at 20 ± 2°C with the use of an oscillating hotplate or a
magnetic stirrer. Filter the solution, with a filter paper Whatman no.40 and a glass
funnel, into a 50 mL centrifuge tube, wash with a few mL of deionized water, add 1 mL
of concentrated nitric acid, and make up to volume with deionized water.
