General: | |||
Overall Dimensions: | 380 wide x 365 deep x 665 mm high | ||
Weight of Instrument: | 55 kg net. | ||
Electricity Supply: | 110/240 volts AC. 60/50 Hz. 1 ph. 24 watts max. | ||
Air Supply: | Standard Model 300 kPa. 4.5L Free air per minute. or 1.5L Free air per cycle. | ||
Maximum Jig Height: | 120 mm. | ||
Minimum Jig Height: | 30 mm. | ||
Weight of Jig: | 1830 g. | ||
Load Ranges: | |||
Standard: | 0 - 2.2 kN | 0 - 225 kgf | 0 - 500 lbf |
Available: | 0 - 220 N | 0 - 22 kgf | 0 - 50 lbf |
0 - 1.1 kN | 0 - 112kgf | 0 - 250 lbf | |
Operating Speeds: | |||
Fast approach: | 2 mm/sec. maximum. | ||
Minumum rate of load increase on Standard Model: | 0.25 N/sec. | ||
原文由 tutm(tutm) 发表:
英国华莱士仪器公司(Wallace Instruments),有台仪器应该就是做这个的,“Compression Stress Relaxometer Mk III - C11”,只是可能要他们配上ASTM的测试头,楼主可以看下
http://www.wallaceinstruments.co.uk/products/compression/wallace-compression-stress-relaxometer-mk-iii-c11
夹具
General:
Overall Dimensions:
380 wide x 365 deep x 665 mm highWeight of Instrument:
55 kg net.Electricity Supply:
110/240 volts AC. 60/50 Hz. 1 ph. 24 watts max.Air Supply:
Standard Model 300 kPa. 4.5L Free air per minute. or 1.5L Free air per cycle.Maximum Jig Height:
120 mm.Minimum Jig Height:
30 mm.Weight of Jig:
1830 g.
Load Ranges:Standard:
0 - 2.2 kN
0 - 225 kgf
0 - 500 lbfAvailable: 0 - 220 N 0 - 22 kgf 0 - 50 lbf 0 - 1.1 kN 0 - 112kgf 0 - 250 lbf
Operating Speeds:Fast approach:
2 mm/sec. maximum.Minumum rate of load increase on Standard Model:
0.25 N/sec.
