Object capability工件尺寸 | cylinder Diameter 工件直径 | max.620 mm | |
Length 长度 | <600mm, 1200mm with turn over | ||
Weight 重量 | max. 65 kg | ||
Operation mode 操作模式 | 3D-CT | Computed Tomography (cone beam geometry) 计算机断层扫描(锥束扫描) | |
SFE-mode SFE模式 | |||
DR | Digital Radiography 数字成像 | ||
Measurement time 扫描时间 | CT | Down to 15s – 4min. per slice Min. scan time incl. reconstruction: 30s/slice | |
typical data acquisition time for high resolution measurements; scan time depends on object size and material 高分辨率测量典型数据采集时间,扫描时间取决于工件尺寸和材料。 | |||
Magnification 放大 | 1.14… 4 times | ||
Contrast resolution CT 对比度分辨率 | <0.5% | ||
备注: · Contrast Sensitivity 对比灵敏度(对比度分辨率);Spatial Resolution 空间分辨率 · Approx.0.2mm resolution of detail /< 0.1mm accuracy of measurement细节分辨率约为0.2mm /测量精度 < 0.1mm · density resolution depends on material 密度分辨率与材料有关 · According to ASTM E1695-95 分辨率依据ASTM E1695-95定义 | |||
High image quality even at fast scans: optimized geometry 快速扫描同时可得到高图像质量,最优化测量 | |||
Objects can be scanned with continuous rotation: no vibrations, no time consuming Stop & Go mode 可以通过持续旋转扫描得到:无振动,无时间消耗停止& 运行模式 |
Technical data技术参数 | ||
High voltage range高压范围 | 20- 450 kV | |
Tube current管电流 | 0 - 15mA | |
Max. Generator power 最大功率 | 4.5KW | |
Focal spot size焦点尺寸 | 0.4mm/1.0mm | |
Functions功能 | Autostart, Autofocus, Isowatt mode 自动启动,自动焦点,恒功率 |
