150.6 蒸发光散射检测-高效液相色谱法测定龙生蛭胶囊中黄芪甲苷的含量
【作者】
王巧灵;
雷亚贤;
姚薇;
高祥祥;
【Author】 WANG Qiao-ling,LEI Ya-xian,YAO Wei,GAO Xiang-xiang(Xianyang Buchang Pharmaceutical Co.,Ltd.712000,China)
【机构】
咸阳步长制药有限公司;
咸阳步长制药有限公司 陕西西安712000;
陕西西安712000;
【摘要】 目的建立高效
液相-蒸发光散射检测法测定龙生蛭胶囊中黄芪甲苷的含量。方法色谱柱为Diamonsil C18(250mm×4.6 mm,5μm)。流动相为乙腈-水(33∶67),流速1.0 ml/min。ELSD参数:漂移管温度105℃,气体流量2.8 ml/min。结果黄芪甲苷在2.45~10.64μg的线性关系良好(r=0.999 2,n=5)。结论方法简便准确,重现性好,灵敏度高。 更多还原
【Abstract】 Objective To establish an HPLC-ELSD method for determining the contents of astragaloside in Longshengzhi capsules.Methods The chromatographic column was Diamosil C18(250 mn×4.6 mm,5 μm).The mobile phase was ace tonitrile-water(33∶67)and the flow rate was 1.0 ml/min.The drift tube temperature was at 105℃.The gas flow rate was at 2.8 ml/min.Results Within the range of 2.45~10.64 μg,the content of astragaloside had a good linear ratationship(r=0.999 2,n=5).Conclusion The method is easy,reliable,sen... 更多还原
【关键词】
蒸发光散射检测-高效[url=https://insevent.instrument.com.cn/t/5p]液相色谱[/url];
龙生蛭胶囊;
黄芪甲苷;
