149.9 锡类缓释贴膜中靛蓝的含量测定
【作者】
王小平;
何晓晖;
金火星;
【Author】 WANG Xiao-ping1,HE Xiao-hui1,JIN Huo-xing2(1.Jiangxi College of Chinese Medicine,Fuzhou 344000,China;2.The People’s Hospital of Fengcheng City,Fengcheng 331100,China)
【机构】
江西中医药高等专科学校;
江西省丰城市人民医院 江西抚州344000;
江西抚州344000;
331100;
【摘要】 目的建立锡类缓释贴膜中靛蓝的含量测定方法。方法采用Diamonsil C18柱;流动相为甲醇-0.2%醋酸(68∶32);检测波长285 nm;结果靛蓝的线性范围为1.1~5.5μg,r=0.999 9;平均回收率为97.0%,RSD=1.01%。结论该含量测定方法准确、稳定,可用于锡类缓释贴膜的质量控制。 更多还原
【Abstract】 Objective To establish a method for the determination of indigotin in Xilei oral sustained-release mucoadhesive films.Methods The C18 column was used.The mobile phase was composed of methanol-0.2 %acetic acid solution(68∶32).The detection wavelength was 285 nm.Results The calibration curve of indigotin was linear in the range of 1.1~5.5μg(r=0.9999)with average recovery 97.0%(RSD=1.01 %).Conclusion The determination method is accurate,stable and can be used to control the quality of Xilei Oral Su... 更多还原
【关键词】
高效[url=https://insevent.instrument.com.cn/t/5p]液相色谱法[/url];
锡类;
口腔缓释贴膜;
靛蓝;
