Safety Phrases | 英文解释 | 中文解释 |
S1 | Keep locked up. | 上锁; |
S1/2 | Keep locked up and out of reach of children. | 上锁保管并避免儿童触及; |
S2 | Keep out of reach of children. | 避免儿童触及; |
S3 | Keep in a cool place. | 保存在阴凉处; |
S3/14 | Keep in a cool place away from ... (incompatible materials to be indicated by the manufacturer). | 保存在阴凉场所,远离(生产厂家指明的不兼容的物料); |
S3/7 | Keep container tightly closed in a cool place. | 将容器严格密闭保存在阴凉处; |
S3/7/9 | Keep container tightly closed in a cool, well-ventilated place. | 将容器严格密闭保存在阴凉、通风良好场所; |
S3/9 | Keep in a cool, well-ventilated place. | 保存在阴凉、通风良好场所; |
S3/9/14 | Keep in a cool, well-ventilated place away from ... (incompatible material to be indicated by the manufacturer) | 保存在阴凉、通风良好场所,远离(生产厂家指明的不兼容的物料); |
S3/9/14/49 | Keep only in the original container in a cool, well-ventilated place away from ... | 保存在原始容器中,放在阴凉通风良好场所,远离(生产厂家指明的不兼容的物料); |
S3/9/49 | Keep only in the original container in a cool, well-ventilated place. | 保存在原始容器中,放在阴凉、通风良好场所; |
S4 | Keep away from living quarters. | 远离生活区; |
S5 | Keep contents under ... (appropriate liquid to be specified by the manufacturer). | 将该物质保存在生产厂家指定的适当液体中; |
S6 | Keep under ... (inert gas to be specified by the manufacturer). | 将该物质保存在生产厂家指定的惰性气体中; |
S7 | Keep container tightly closed. | 保存在严格密闭容器中; |
S7/47 | Keep container tightly closed and at a temperature not exceeding ...鳦. (to be specified by the manufacturer) | 保持容器严格密闭,温度不超过….°C(由生产厂家指定); |
S7/8 | Keep container tightly closed and dry. | 保存在严格密闭容器中,保持干燥; |
S7/9 | Keep container tightly closed and in a well-ventilated place | 保持容器严格密闭,置于通风良好的场所; |
S8 | Keep container dry. | 保持容器干燥; |
S9 | Keep container in a well-ventilated place. | 保持容器在通风良好的场所; |
S12 | Do not keep the container sealed. | 不要将容器密封; |
S13 | Keep away from food, drink and animal feeding stuffs. | 远离食品、饮料和动物饲料保存; |
S14 | Keep away from ... (incompatible materials to be indicated by the manufacturer). | 远离(生产厂家指定的不相容物质)保存; |
S15 | Keep away from heat. | 远离热源; |
S16 | Keep away from sources of ignition - No smoking. | 远离火源,禁止吸烟; |
S17 | Keep away from combustible material. | 远离可燃物料; |
S18 | Handle and open container with care. | 小心搬运和开启容器; |
S20 | When using do not eat or drink. | 使用时,不得进食,饮水; |
S20/21 | When using do not eat, drink or smoke. | 使用时,不得进食,饮水或吸烟; |
S21 | When using do not smoke. | 使用时,禁止吸烟; |
S22 | Do not breathe dust. | 不要吸入粉尘; |
S23 | Do not breathe gas/fumes/vapour/spray. | 不要吸入气体/烟雾/蒸汽/喷雾; |
S24 | Avoid contact with skin. | 避免皮肤接触; |
S24/25 | Avoid contact with skin and eyes。 | 避免皮肤和眼睛接触; |
S25 | Avoid contact with eyes. | 避免眼睛接触; |
S26 | In case of contact with eyes, rinse immediately with plenty of water and seek medical advice. | 眼睛接触后,立即用大量水冲洗并征求医生意见; |
S27 | Take off immediately all contaminated clothing. | 立即脱掉全部污染的衣服; |
S28 | After contact with skin, wash immediately with plenty of ... (to be specified by the manufacturer). | 皮肤接触后,立即用大量...(由生产厂家指定)冲洗; |
S29 | Do not empty into drains. | 不要排入下水道; |
S29/56 | Do not empty into drains, dispose of this material and its container at hazardous or special waste collection point. | 不要排入下水道,在危险废物或特殊废物收集点处置 |
S30 | Never add water to this product. | 切勿将水加入该产品中; |
S31 | Keep away from explosive materials. | 远离爆炸物质; |
S33 | Take precautionary measures against static discharges. | 对静电采取预防措施; |
S34 | Avoid shock and friction. | 避免冲击和摩擦; |
S35 | This material and its container must be disposed of in a safe way. | 该物料及其容器必须以安全方式处置; |
S36 | Wear suitable protective clothing. | 穿戴适当的防护服; |
S36/37 | Wear suitable protective clothing and gloves. | 穿戴适当的防护服和手套; |
S36/37/39 | Wear suitable protective clothing, gloves and eye/face protection. | 穿戴适当的防护服、手套和眼睛/面保护; |
S36/39 | Wear suitable protective clothing and eye/face protection. | 穿戴适当的防护服和眼睛/面保护; |
S37 | Wear suitable gloves. | 戴适当手套; |
S37/39 | Wear suitable gloves and eye/face protection. | 穿戴适当的手套和眼睛/面保护; |
S38 | In case of insufficient ventilation, wear suitable respiratory equipment. | 通风不良时,佩带适当的呼吸器; |
S39 | Wear eye/face protection. | 戴眼睛/面孔保护装置; |
S40 | To clean the floor and all objects contaminated by this material, use ... (to be specified by the manufacturer). | 使用….(由生产厂家指定)清洗地面和被这种物料污染的所有物品; |
S41 | In case of fire and/or explosion do not breathe fumes. | 着火和/或爆炸时,不要吸入烟雾; |
S42 | During fumigation/spraying wear suitable respiratory equipment. | 熏蒸/喷洒时,戴适当呼吸器(由生产厂家指定); |
S43 | In case of fire, use ... (if water increases the risk, add - never use water). | 着火时使用(指明具体的消防器材种类,如果用水增加危险,注明“禁止用水” |
S44 | If you feel unwell, seek medical advice (show the label where possible). | 如果你感觉不适,征求医生意见(可能时出示标签); |
S45 | In case of accident or if you feel unwell, seek medical advice immediately (show the lable where possible). | 发生事故时或感觉不适时,立即求医(可能时出示标签); |
S46 | If swallowed, seek medical advice immediately and show this container or label. | 食入时,立即求医并出示容器/标签; |
S47 | Keep at temperature not exceeding ... degr. C (to be specified by the manufacturer). | 保持温度不超过……°C(由生产厂家指定); |
S47/49 | Keep only in the original container at temperature not exceeding ... degr. C (to be specified by the manufacturer) | 保存在原始容器中,温度不超过…°C(由生产厂家指定); |
S48 | Keep wetted with ... (appropriate material to be specified by the manufacturer). | 用……(生产厂家指定的适当物料)保持湿润; |
S49 | Keep only in the original container. | 仅保存在原始容器中; |
S50 | Do not mix with ... (to be specified by the manufacturer). | 不要与……(由生产厂家指定)混合; |
S51 | Use only in well-ventilated areas. | 仅在通风良好的场所使用; |
S52 | Not recommended for interior use on large surface areas. | 建议不在表面积大的区域内部使用; |
S53 | Avoid exposure - obtain special instructions before use. | 避免接触,使用前获得特别指示说明; |
S54 | Obtain the consent of pollution control authorities before discharging to wastewater treatment plants. | 在排放入污水处理厂前获得官方污染控制机构许可; |
S55 | Treat using the best available techniques before discharge into drains or the aquatic environment. | 在排入污水道和水生环境前进行最佳技术处理; |
S56 | Dispose of this material and its container at hazardous or special waste collection point. | 在危险废物或特殊废物收集点处置该物料及其容器; |
S57 | Use appropriate containment to avoid environmental contamination. | 使用适当容器避免环境污染; |
S58 | To be disposed of as hazardous waste. | 作为危险废物进行处置; |
S59 | Refer to manufacturer/supplier for information on recovery/recycling. | 参考生产厂家/供货商提供的回收/再生利用信息; |
S60 | This material and/or its container must be disposed of as hazardous waste. | 该物质及其容器必须作为危险废物处置; |
S61 | Avoid release to the environment. Refer to special instructions/Safety data sheets. | 避免释放到环境中,参考特别指示/安全收据说明书; |
S62 | If swallowed, do not induce vomiting: seek medical advice immediately and show this container or label. | 吞食后不要催吐:立即求医并出示该容器或标签; |
S14A | Keep away from acids, reducing agents and polymerisation catalysts. | 远离酸、还原剂、聚合催化剂保存; |
S14B | Keep away from organic material and metal powders. | 远离有机金属化合物和金属粉末保存; |
S14C | Keep away from water, acids and alkali. | 远离水、酸、碱保存; |
S28A | After contact with skin, wash immediately with plenty of water. | 皮肤接触后,立即用大量水冲洗; |
S28B | After contact with skin, wash immediately with plenty of water and soap. | 皮肤接触后,立即用大量水、肥皂冲洗; |
S28C | After contact with skin, wash immediately with a sodium borate solution. | 皮肤接触后,立即用大量硼酸钠溶液冲洗; |
S43A | In case of fire, use dry chemical. (never use water) | 着火时使用干粉消防器材种类灭火(禁止用水); |
S43B | In case of fire, use fire-fighting equipment on basis of sodium chloride or sodium bicarbonate (never use water). | 着火时使用氯化钠或碳酸氢钠类型的消防器材种类灭火(禁止用水); |
S43C | In case of fire use limestone powder, sodium chloride or dry sand (never use water). | 着火时使用石灰粉末、氯化钠或干沙子灭火(禁止用水); |
S43D | In case of fire, use sodium carbonate or dry sand (never use water). | 着火时使用碳酸钠或干沙子灭火(禁止用水); |
S43E | In case of fire, use dry sand (never use water). | 着火时使用干沙灭火(禁止用水); |
S43F | Use water in case of Fire | 用水灭火; |
S47A | Keep at temperature not exceeding 65 degr. C. | 保持温度不超过65°C; |
S50A | Do not mix with acids. | 不要与酸混合; |
S5A | Keep contents under oil. | 将该物质保持在油中; |
S5B | Keep contents under liquids which are oxygen-free, e.g. kerosene, toluene, etc. | 将该物质保持在无氧液体中,如煤油、甲苯等; |
S6A | Keep under nitrogen. | 将该物质保持在氮气中; |
