269.2 不同产地大黄药材中没食子酸和儿茶素的比较
作 者:芦雅丽[1] 赵建邦[2] 宋平顺[2]
LU Ya-li,ZHAO Jian-bang,SONG Ping-shun (1.Pharmacy College of Lanzhou University,Lanzhou 730000,China;2.Gansu Provincial Institute for Food and Drug Control,Lanzhou 730000,China)
机构地区:[1]兰州大学药学院,甘肃兰州730000 [2]甘肃省食品药品检验所,甘肃兰州730000
出 处:《中成药》 CAS CSCD 2011年第33卷第5期 832-834页,共3页
Chinese Traditional Patent Medicine
基 金:甘肃省科技厅项目(GS035-A43-048-03); [国家科技重大专项课题]中药标准物质研制和开发技术平台(2009ZX09308-001)
摘 要:目的建立不同产地(甘肃、四川、青海、安徽和重庆)大黄药材中没食子酸、儿茶素的测定方法。方法采用超声提取法;用反相高效
液相色谱法,色谱柱为Diamonsil C18(4.6 mm×250 mm,5μm),流动相为甲醇-水(含0.1%磷酸)梯度洗脱,体积流量1 mL/min,检测波长280 nm,柱温为室温,按外标法定量。结果没食子酸在0.106~2.125μg范围内线性关系良好,加样回收率平均为99.3%,RSD为0.71%;儿茶素在0.465~9.296μg范围内线性关系良好,加样回收率平均为98.9%,RSD为2.06%。结论对不同产地的大黄药材中的儿茶素和没食子酸进行了比较,所建立方法简便快速,结果准确、稳定,可以作为大黄药材的质量评价方法。
AIM To establish a method for determing the contents of gallic acid and catechin in Rheum palametum,and compare the contents from different habitats including Gansu,Sichuan,Oinghai,Anhui provinces,and Chongqin city.METHODS The samples were extracted with ultrasound method and analyzed on Waters C18 column under gradient elution.The mobile phase was methanol-0.1% ortho-phosphoric acid and the flow rate was 1.0 mL/min.The wavelength of UV detector was set at 280 nm,the column temperature was room temeperature,and the quantification was performed with external standard method.RESULTS The linear range of gallic acid was 0.106-2.125 μg,the average recovery was 99.3%,and the RSD was 0.71%.The linear range of catechin was 0.465-9.296 μg,the average recovery was 98.9%,and the RSD was 2.06%.CONCLUSION The method is quick,simple and accurate,and it can be used for the quality control of Rheum palametum.
关 键 词:大黄 没食子酸 儿茶素,HPLC
Rheum palametum gallic acid catechin HPLC
分 类 号: R284.1 [医药、卫生 > 中国医学 > 中药学 > 中药化学]
