主题:【第六届原创】电位控制技术
浏览0 回复6 电梯直达
旷世大器材
维权声明:本文为v2762510原创作品,本作者与仪器信息网是该作品合法使用者,该作品暂不对外授权转载。其他任何网站、组织、单位或个人等将该作品在本站以外的任何媒体任何形式出现均属侵权违法行为,我们将追究法律责任。
The basis of all controlled-potential techniques is the measurement of the current response to an applied potential. A multitude of potential excitations (including a ramp, potential steps, pulse trains, a sine wave, and various com-binations thereof) exists. The present chapter reviews those techniques that are widely used.
1.CHRONOAMPEROMETRY
Chronoamperometry involves stepping the potential of the working electrode from a value at which no faradaic reaction occurs to a potential at which the surface concentration of the electroactive species is effectively zero (Fig. 1a). A stationary working electrode and unstirred (quiescent) solution are used. The resulting current–time dependence is monitored. As mass transport under these conditions is solely by diffusion, the current–time curve reflects the change in the concentration gradient in the vicinity of the surface . This involves a gradual expansion of the diffusion layer associ-ated with the depletion of the reactant, and hence decreased slope of the con-centration profile as time progresses (see Fig. 1b). Accordingly, the current
(at a planar electrode) decays with time (Fig. 1c), as given by the Cottrell equation
Figure 1 Chronoamperometric experiment: (a) potential–time waveform; (b) change in concentration profiles as time progresses; (c) the resulting current–time response.
  1-1
where  n, F, A, C, D, and  t are the number of electrons, Faraday’s constant, the surface area, the concentration, the diffusion coefficient, and time, respectively. Such an  it1/2 constancy is often termed a “Cottrell behavior.” Deviations from such behavior occur at long times (usually over 100 s) as a result of natural convection effects, due to coupled chemical reactions, and when using non-planar electrodes or microelectrodes with high perimeter : area ratio . In the latter case, a time-independent current (proportional to the concentration) is obtained for  t > 0.1 s, due to a large radial diffusion con-tribution. Similar considerations apply to spherical electrodes whose current response following potential step contains time-dependent and time-independent terms . Recall also that for short values of  t (t < 50 ms),
the chronoamperometric signal contains an additional background contribu-tion of the charging current . This exponentially decaying charging current represents the main contribution to the response in the absence of an electroactive species.
Chronoamperometry is often used for measuring the diffusion coefficient of electroactive species or the surface area of the working electrode. Some analytical applications of chronoamperometry rely on pulsing of the potential of the working electrode repetitively at fixed time intervals. Some popular test strips for blood glucose involve potential-step measurements of an enzymatically liberated product (in connection with a preceding incubation reaction). Chronoamperometry can also be applied to the study of mechanisms of electrode processes. Particularly attractive for this task are reversal double-step chronoamperometric experi-ments (where the second step is used to probe the fate of a species generated in the first one).
The potential-step experiment can also be used to record the charge–time dependence. This is accomplished by integrating the current resulting from the potential step and adding corrections for the charge due to the double-layer
charging (Qdl ) and reaction of the adsorbed species (Qi ):
1-2
Such a charge measurement procedure, known as chronocoulometry , is par-ticularly useful for measuring the quantity of adsorbed reactants (because of the ability to separate the charges produced by the adsorbed and solution species). A plot of the charge ( Q) versus t 1/2 , known as an  Anson plot , yields an intercept at  t = 0 that corresponds to the sum of  Qdl and  Qi . The former can be estimated by subtracting the intercept obtained in an identical experiment carried out in the blank solution.
Thank you .
zhw19811005
旷世大器材
原文由 zhw19811005(zhw19811005) 发表:
专业英语太强了。
我觉得还好吧
小五
原文由 旷世大器材(v2762510) 发表:
专业英语太强了。
我觉得还好吧
楼上大神。。。 我网页能自动翻译都看着累、、、、
影子
旷世大器材
影子
原文由 影子(hyheying) 发表:
http://wenku.baidu.com/view/67a1eaca050876323112121f.html
你又知道了 要淡定
我相当淡定,楼主如果能翻译一下,弄个中英对照其实也很不错的
手机版: 电位控制技术
