主题:请问:关于用DAD检测器检测共流出杂质的问题。
浏览0 回复0 电梯直达
wittyzhou
我做食品中一种成分的检测,但是要用二极管阵列检测器确定是否和这种成分有共流出的杂质,
我看了一篇国外的资料,他说看杂质因子是否远大于域值,如果是的话就说明该种物质不含共流出的杂质。
这些我不是很懂希望用过DAD的老师解答一下,谢谢,
原文:Purity factor is calculated based on the similarity in the shape of spectra and, if the peak is pure,the purity value should be  greater than the  threshhold value, calculated by taking into account the system baseline noise
