可惜这里不能传图,我就再传些资料吧
For storage of volatile materials in areas with explosive atmospheres. Red warning label on front reads: "Explosion-Proof Refrigerator." For added safety, units have top-mounted hydraulic thermostats and door stops, compressors with enclosed overloads and relays, and static condensers and evaporators free of electric fans.
Both models feature permit setpoint adjustment while running. Manual defrost and CFC-free refrigerant. For 115V 60Hz. Note: units are not equipped with line cord and plug; must be hardwired into an appropriately rated conduit box to comply with NEC code.
The two-door 11 cu. ft. (311L) model has an 8.5 cu. ft. (241L) refrigerator and 2.5 cu. ft. (71L) freezer. Temperature ranges: 2° to 10°C (refrigerator), -18° to -5°C (freezer). White enamel-coated steel exterior, white ABS plastic interior. Refrigerator has four fixed white epoxy-coated steel shelves (total shelf capacity: 15.5 sq. ft.) Freezer has one fixed shelf, one door compartment. Overall dimensions, 241/2L x 231/2W x 69 in.H (62 x 60 x 175cm). Length includes handles; height includes top-mounted controls. Two adjustable and two fixed pads on bottom allow easy installation and leveling. Unit requires air clearance of 3 in. (5.1cm) around top and back, 1/2 in. (1.3cm) on sides. Complies with OSHA 29CFR1910.307. UL listed for Class 1 and Groups C and D hazard locations. CSA approved. Shipping weight, 195 lb. (89kg). Two-year warranty on parts, labor, and travel; five-year warranty on compressor.
The single-door 30 cu. ft. (850L) model has a 25 cu. ft. (708L) refrigerator and 5 cu. ft. (142L) freezer. Features white baked-on polyester enamel exterior, white epoxy-coated steel interior with ABS plastic door liner and keylocked power switch. Refrigerator and freezer temperatures are user-selectable in °C or °F with 0.1° resolution. Refrigerator temperature range: 3° to 13°C (37° to 55°F) with ±4°C stability. Freezer temperature range: -15° to +4°C (5° to 39°F). Internal door separates stainless-steel freezer compartment from refrigerator. Shelves are white epoxy-coated steel; include three fixed, five adjustable, and one half-depth shelf for a total capacity of 38.75 sq. ft. Unit dimensions: 35L x 351/2W x 82 in.H (89 x 90 x 208cm). Length includes handle; height includes top-mounted controls. Four legs on bottom allow easy installation and leveling. Unit requires air clearance of 4 in. (10cm) around top, back and sides. UL listed, CSA approved; complies with OSHA 29CFR1910.307. Shipping weight, 370 lb. (168kg). Two-year warranty on parts and labor; five-year warranty on compressor.
Refrigerator, Explosion-proof, Fisher Isotemp*, 20.6 cu. ft., 2° to 10°C, 1 hinged solid door, 1/4hp, manual defrost, 115V 60Hz
Each for $3,270.35
Refrigerator/Freezer, Explosion-proof, Fisher Isotemp*, 25 cu. ft. Refrigerator/5 cu. ft. Freezer, 1 solid hinged door, 115V 60Hz
Each for $4,889.40
