点击此处下载(pdf)1.What is cyclic voltammetry, and why is it so commonly used? In a cyclic voltammetry experiment, as in other controlled potential experiments, a potential is applied to the system, and the faradaic current response is measured (a faradaic current is the current due to a redox reaction). The current response over a range of potentials (a potential window) is measured, starting at an initial value and varying the potential in a linear manner up to a pre-defined limiting value. At this potential (often referred to as a switching potential), the direction of the potential scan is reversed, and the same potential window is scanned in the opposite direction (hence the term cyclic). This means that, for example, species formed by oxidation on the first (forward) scan can be reduced on the second (reverse) scan. This technique is commonly used, since it provides an fast and simple method for initial characterization of a redox-active system. In addition to providing an estimate of the redox potential, it can also provide information about the rate of electron transfer between the electrode and the analyte, and the stability of the analyte in the electrolyzed oxidation states (e.g., do they undergo any chemical reactions).
2. What is potentiostatic control of an electrode?A control voltage is fed into the control input CI. This control voltage forces a current through the counter electrode exactly as high as to achieve the wanted potential difference between working electrode and reference electrode. The control voltage may be produced by the internal potential control source of the potentiostat, or by an external signal generator, e.g. a ramp generator or a sine wave generator. While for a constant potential the internal potential control source is sufficient, time-dependent signals are to be fed from external sources (except our scanning potentiostats that also have built-in voltage scanners).
3.Why are the peaks in a cyclic voltammogram asymmetric (tailed)?The asymmetry is due to the diffusion of analyte from the bulk solution to the electrode surface during the experiment. In experiment where the analyte is attached (adsorbed) to the electrode surface, the peaks are symmetric. Actually, even for monolayer modified electrodes the peaks are not symmetrical, unless the system is completely reversible.
4. Why can cyclic voltammograms of the same system look inverted when done by different groups?This is due to the existence of different conventions for plotting current and potential. For any voltammogram, current is plotted along the y-axis, and potential along the x-axis. In one convention (called classical or polarographic), potentials become more negative along the (positive) x-axis, and reduction (cathodic) currents are positive. In the other convention (IUPAC), the opposite is applies. If you don't want problems with your papers, you have to use the IUPAC convention: anodic current is positive and positive potentials are right-hand plotted.
5. What are the characteristic parameters of a cyclic voltammogram?The parameters of a cyclic voltammogram are the peak potential and the peak current (the peak width at half the peak current is also sometimes measured). Since there are two peaks associated with a redox reaction (one on the forward scan and one on the reverse scan), it is standard practice to quote the difference of the peak potentials and the ratio of the peak currents.
What is cyclic voltammetry.pdf
