Pharmaceutical Samples. One important application area of FT-IR imaging is pharmaceutical sample analysis. Many pharmaceutical compounds are known to crystallize in different polymorphic forms. Physical properties of these compounds such as solubility, melting point, density, hardness, optical properties, vapor pressure and so forth may all vary with the polymerphic form. The polymorphic distribution of crystal film preparation as well as the molecular and crystal structure of a given pharmaceutical compound affect the efficacy of a drug and may carry enormous legal implications. FT-IR imaging provides a mean of obtaining detailed information on the distribution of molecular and crystal structures. Primidone (5-ethyl-5-phenyl-hexahydrophrimidine-4,6-dione) is frequently used as an anti-convulsant that is effective in the treatment of grand mal psychomotor epilepsy and Jacksonian seizures. Shown in Figure 5.7 are an IR image at 1671cm-1, corresponding to the amide I absorption band, and a visible image with visible polarized light for a primidone polycrystalline file. A quick comparison between the visible and the infrared images clearly indicates visual contrast enhancement on the IR image. Three single pixel spectra at different locations are shown, each representing a 6×6µm2 area on the sample. Comparisons between the individual spectra revealed distinct differences in the C-H stretching region, the stretching vibration of the amide I band (1706-1554cm-1), and the N-H deformation band (1650-1550cm-1), all indicative of at least two, possible three polymorphs.
