The integrand in the above equation can be expanded and further expressed in terms of Bessel functions Jn(2πσε), where n=0,1,2,3,……, and sin(2mπfΦMt), where m=1,2,3…… When a DSP board or a phase sensitive lock-in amplifier is used to demodulate the detector signal at the fundamental ΦM frequency, only the J1(2πσε)term is significant, and therefore, the demodulated ΦM interferogram can be expressed as
Thus, the ΦM interferogram (in the absence of phase errors) is antisymmetric with respect to the zero path difference (ZPD) and is the derivative of the amplitude modulation interferogram. In addition, the integrand is convolved with the first order Bessel function, J1(2πσε), and thus the demodulated ΦM interferogram and single-beam profiles depend on ΦM amplitude, ΦM frequency and energy of the light.
