主题:彻底揭密ARL软件(3)
浏览0 回复3 电梯直达
happy_cheng
扩展名------ 类型 --------------------------------------------详细解释
MIO--Manual ICS Dialogue File ---------------Terminal Mode commands used for QA facilities
MSK--Database-------------------------------- Instrument alarms and modification reasons.
MVR--MVR save state File--------------------- All data saved resulting from Regression computations.
PRG--Analytical program Files-----------------Global Analytical Data for Analysis
QUA--Quality File-----------------------------All data related to Quality used for Quality check.
RXB--Reception Buffering File-----------------This contains data received from device i.e.EXAN.
S1--Main database File-------------------------Contains instrument
configuration,analytical conditions setting-up samples,...
S2--Main database File------------------- -----Contains instrument configuration,analytical conditions setting-up samples,...
SEL--Material selection file--------------------Global data using Material used for change correction
SRC--Import/Export Raw--------------------------Error Massage,Data File Alarm,etc.Used for Database Generator,These Files may be copied and then imported into the Database.
(continue)
jiazailuxinan
wccd
原文由 jiazailuxinan(jiazailuxinan) 发表:
谢谢分享,学习了,翻译一下最好
认同!
juway
