原文由 大布口袋(taboo) 发表:
Three ways to shift a spectrum
1. Magnetic prism – changing prism strength (Energy Shift)
2. High tension – electron accelerating voltage (Offset)
3. Drift tube – an extra retarding magnetic field, which responds faster than others, up to 1000eV shift (Drift Tube)
Default
1. Spectroscopy: Energy Shift (or Drift Tube) – not to compromise the illumination in STEM
2. Imaging: Offset – so electrons used to form the filtered image are at the alignment energy while travelling in the imaging system
原文由 xdd1987(xdd1987) 发表:原文由 大布口袋(taboo) 发表:
Default
我看三楼的说不要用drift tube,楼主能帮忙解释一下吗?
