塑料产品可以做哪些物理测试呢
Shore Hardness Type A /D ASTM D2240-05(2010)
ISO 868-2003
邵氏A /D型硬度 GB/T 2411-2008
ball indentation hardness ISO 2039-1:2001
球压痕硬度 GB/T 3398.1-2008
Tensile Strength/ Elongation at break /Tensile Modulus ASTM D638-10
拉伸强度、断裂伸长率、拉伸模量 ISO 527-2:1993/Cor.1:1994
GB/T 1040.2:2006
Poisson ratio ASTM D638-10
泊松比
Flexural Strength /Flexural modulus ASTM D790-10
ISO 178-2010
弯曲强度、弯曲模量 GB/T 9341-2008
IZOD Impact Strength ASTM D256-10(有缺口)
ASTM D4812-06(无缺口)
悬臂梁冲击强度 ISO 180:2000/Amd 1:2006
GB/T 1843-2008
CHARPY Impact Strength ASTM D6110-10
简支梁冲击强度 ISO 179-1-2010
GB/T 1043.1-2008
Compressive Strength /Compressive Modulus ASTM D695-10
ISO 604-2002
压缩强度、压缩模量 GB/T 1041-2008
Falling Weight Impact Strength ASTM D5420-10(Gardner Impact)
落锤冲击强度 ASTM D4226-10(PVC建材)
Taber Abrasion Resistance ASTM D1044-08(透明塑料)
ISO 9352-1995
磨耗性能(Taber) GB/T 5478-2008
Shear Strength by Punch ASTM D732-10
穿孔剪切强度
Density ASTM D792-08(Immersion)
密度 ISO 1183-1:2004 (Immersion)
GB/T 1033.1-2008(浸泡法)
Melt index(MI) ISO 1133:2005 cor.1-2006
熔融指数 GB/T 3682-2000
ASTM D1238-10
Flow rate ratio ISO 1133:2005 cor.1-2006 C
流动速率比 GB/T 3682-2000 C
ASTM D1238-10 D
Heat deflection temperature(HDT) ASTM D648-07
ISO 75-2:2004
热变形温度 GB/T 1634.2-2004
Vicat softening temperature(VST) ASTM D1525-09
ISO 306:2004
维卡软化点 GB/T 1633-2000
GB/T 8802-2001
ISO 2507-1995
Brittleness temperature ASTM D746-07
低温脆化温度 ISO 974-2000
GB/T 5470-2008
Luminous transmittance ASTM D1003-07e1 A
GB/T 2410-2008 A
透光率 JIS K7361-1:1997
ISO 13468-1:1996
Haze ASTM D1003-07e1 A
雾度 GB/T 2410-2008 A
ISO 14782-1999/Cor 1.2005
Specular gloss ASTM D2457-08
镜面光泽度 ASTM D523-08
GB/T 8807-88
Water Absorption ASTM D570-98(2010)
吸水率 ISO 62-2008
GB/T 1034-2008
Chemical Resitance ASTM D1693-08
耐化学试剂 GB 1842-2008(聚乙烯)
GB/T 2951.41-2008(电缆)
Ball pressure test IEC 60695-10-2-2003
球压测试 GB/T 5169.21-2006
Shrinkage from mold dimension ASTM D955-08 Type A/ D2
ISO 294-4:2001
模具收缩率 GB/T 17037.4-2003
GB/T 15585-1995
Specimen preparation from injection molding 参考相关材料性能参数
注塑加工制样
