原文由 chemlili1999 发表:
What is the precision of the method for concentrations near the quantification limit? I suggest the evaluation of linearity using the quantification limit as the lower point in the calibration curve.
quantification limit 是不是检出线?如果是,为什么要考察在检出线的精密度?线性范围的最低点不是应该为检出线的3倍或者10倍吗?
实在有点困惑
谢谢高手指点!
