序号 | 时间 | C*1 | Si*1 | Si*3 | Mn*3 | Mn*4 | P*1 | S*1 | Cr*2 | Ni*2 | Ni*3 | Mo*1 | Cu*2 | Ti*2 | Al*6 | V*2 | Nb*1 |
1 | 11-2 10:40 | 0.049 | 0.793 | 0.827 | 1.316 | 1.407 | 0.028 | 0.0114 | 16.305 | 12.150 | 12.102 | 2.228 | 0.210 | 0.428 | 0.105 | 0.061 | 0.055 |
2 | 11-2 12:15 | 0.048 | 0.791 | 0.824 | 1.308 | 1.404 | 0.031 | 0.0115 | 16.100 | 12.180 | 12.049 | 2.253 | 0.210 | 0.425 | 0.105 | 0.060 | 0.055 |
3 | 11-2 13:08 | 0.048 | 0.794 | 0.823 | 1.315 | 1.417 | 0.029 | 0.0113 | 16.320 | 12.072 | 12.083 | 2.244 | 0.209 | 0.429 | 0.108 | 0.060 | 0.056 |
4 | 11-2 14:00 | 0.049 | 0.793 | 0.820 | 1.319 | 1.411 | 0.030 | 0.0114 | 16.317 | 12.126 | 12.124 | 2.259 | 0.210 | 0.424 | 0.107 | 0.060 | 0.056 |
5 | 11-2 14:50 | 0.049 | 0.789 | 0.819 | 1.316 | 1.409 | 0.030 | 0.0115 | 16.271 | 12.166 | 12.101 | 2.254 | 0.210 | 0.418 | 0.107 | 0.060 | 0.056 |
6 | 11-2 16:20 | 0.048 | 0.788 | 0.816 | 1.315 | 1.401 | 0.029 | 0.0115 | 16.328 | 12.197 | 12.122 | 2.256 | 0.210 | 0.429 | 0.105 | 0.059 | 0.056 |
7 | 11-3 14:25 | 0.048 | 0.780 | 0.815 | 1.307 | 1.392 | 0.029 | 0.0111 | 16.143 | 12.085 | 12.010 | 2.222 | 0.209 | 0.421 | 0.105 | 0.059 | 0.055 |
8 | 11-3 15:15 | 0.048 | 0.787 | 0.821 | 1.309 | 1.404 | 0.029 | 0.0112 | 16.239 | 12.102 | 12.030 | 2.231 | 0.209 | 0.428 | 0.107 | 0.060 | 0.055 |
9 | 11-3 17:20 | 0.048 | 0.783 | 0.816 | 1.310 | 1.397 | 0.029 | 0.0111 | 16.216 | 12.195 | 12.057 | 2.237 | 0.209 | 0.427 | 0.106 | 0.059 | 0.055 |
10 | 11-5 13:45 | 0.048 | 0.783 | 0.825 | 1.302 | 1.387 | 0.030 | 0.0112 | 16.077 | 12.086 | 11.965 | 2.214 | 0.209 | 0.426 | 0.106 | 0.061 | 0.055 |
平均值 | 0.048 | 0.788 | 0.821 | 1.312 | 1.403 | 0.029 | 0.0113 | 16.232 | 12.136 | 12.064 | 2.240 | 0.209 | 0.425 | 0.106 | 0.060 | 0.055 | |
SD | 0.001 | 0.005 | 0.004 | 0.005 | 0.009 | 0.001 | 0.0002 | 0.095 | 0.048 | 0.052 | 0.016 | 0.001 | 0.004 | 0.001 | 0.001 | 0.000 | |
RSD | 1.11 | 0.61 | 0.52 | 0.40 | 0.63 | 3.35 | 1.43 | 0.58 | 0.39 | 0.43 | 0.70 | 0.34 | 0.84 | 0.96 | 1.00 | 0.78 | |
MAX | 0.049 | 0.794 | 0.827 | 1.319 | 1.417 | 0.031 | 0.0115 | 16.328 | 12.197 | 12.124 | 2.259 | 0.210 | 0.429 | 0.108 | 0.061 | 0.056 | |
MIN | 0.048 | 0.780 | 0.815 | 1.302 | 1.387 | 0.028 | 0.0111 | 16.077 | 12.072 | 11.965 | 2.214 | 0.209 | 0.418 | 0.105 | 0.059 | 0.055 | |
2.83*SD | 0.002 | 0.014 | 0.012 | 0.015 | 0.025 | 0.003 | 0.0005 | 0.268 | 0.135 | 0.147 | 0.044 | 0.002 | 0.010 | 0.003 | 0.002 | 0.001 | |
极差R | 0.002 | 0.014 | 0.012 | 0.017 | 0.029 | 0.003 | 0.0004 | 0.251 | 0.125 | 0.159 | 0.045 | 0.002 | 0.011 | 0.003 | 0.002 | 0.001 | |
重复性限r | 0.006 | 0.024 | 0.024 | 0.028 | 0.028 | 0.003 | 0.0029 | 0.234 | 0.156 | 0.156 | 0.050 | 0.011 | 0.025 | 0.005 | 0.004 | 0.003 |
原文由 dyz(dyz) 发表:
测一下铸铁及高硅钢、超低碳硫钢数据看看
通道 | C*1 | Si*1 | Mn*4 | P*1 | S*1 | Cr*1 | Ni*2 | Mo*1 | Cu*2 | Ti*2 | Al*6 | V*2 | Nb*1 |
1 | 3.3586 | 2.1224 | 0.9936 | 0.4572 | 0.0692 | 1.0176 | 0.5417 | 0.3829 | 0.5215 | 0.0446 | 0.0563 | 0.3166 | 0.0042 |
2 | 3.3786 | 2.1433 | 0.9926 | 0.4707 | 0.0806 | 1.0187 | 0.5411 | 0.3892 | 0.5208 | 0.0452 | 0.0567 | 0.318 | 0.0042 |
3 | 3.39 | 2.1253 | 0.9961 | 0.4643 | 0.07 | 1.017 | 0.5393 | 0.389 | 0.5198 | 0.0458 | 0.0568 | 0.3195 | 0.0042 |
4 | 3.361 | 2.1245 | 0.9957 | 0.4656 | 0.0619 | 1.0183 | 0.5412 | 0.3894 | 0.5204 | 0.0452 | 0.056 | 0.3177 | 0.0043 |
5 | 3.4041 | 2.1419 | 0.996 | 0.4714 | 0.074 | 1.0204 | 0.5404 | 0.3915 | 0.52 | 0.0457 | 0.057 | 0.3209 | 0.0045 |
6 | 3.407 | 2.1543 | 1.0064 | 0.4637 | 0.0784 | 1.0219 | 0.5387 | 0.3926 | 0.5183 | 0.0461 | 0.0577 | 0.3242 | 0.0048 |
7 | 3.3852 | 2.1262 | 1.0063 | 0.448 | 0.0724 | 1.0237 | 0.54 | 0.3896 | 0.5215 | 0.046 | 0.057 | 0.3231 | 0.0047 |
8 | 3.3399 | 2.1442 | 1.0078 | 0.4383 | 0.0663 | 1.0241 | 0.545 | 0.386 | 0.5255 | 0.0453 | 0.0562 | 0.3182 | 0.0038 |
平均值 | 3.3781 | 2.1353 | 0.9993 | 0.4599 | 0.0716 | 1.0202 | 0.5409 | 0.3888 | 0.5210 | 0.0455 | 0.0567 | 0.3198 | 0.0043 |
SD | 0.0234 | 0.0120 | 0.0064 | 0.0115 | 0.0061 | 0.0028 | 0.0019 | 0.0031 | 0.0021 | 0.0005 | 0.0005 | 0.0027 | 0.0003 |
RSD | 0.69 | 0.56 | 0.64 | 2.51 | 8.58 | 0.27 | 0.36 | 0.79 | 0.40 | 1.11 | 0.96 | 0.85 | 7.39 |
MAX | 3.4070 | 2.1543 | 1.0078 | 0.4714 | 0.0806 | 1.0241 | 0.5450 | 0.3926 | 0.5255 | 0.0461 | 0.0577 | 0.3242 | 0.0048 |
MIN | 3.3399 | 2.1224 | 0.9926 | 0.4383 | 0.0619 | 1.0170 | 0.5387 | 0.3829 | 0.5183 | 0.0446 | 0.0560 | 0.3166 | 0.0038 |
2.83*SD | 0.0662 | 0.0341 | 0.0180 | 0.0326 | 0.0174 | 0.0078 | 0.0055 | 0.0087 | 0.0059 | 0.0014 | 0.0015 | 0.0077 | 0.0009 |
极差R | 0.0671 | 0.0319 | 0.0152 | 0.0331 | 0.0187 | 0.0071 | 0.0063 | 0.0097 | 0.0072 | 0.0015 | 0.0017 | 0.0076 | 0.001 |
重复性限r | 0.0785 | 0.0360 | 0.0225 | 0.0258 | 0.0144 | 0.0140 | 0.0063 | 0.0099 | 0.0111 | 0.0032 | 0.0040 | 0.0060 | 0.0013 |
