1: FFT中的斑点和对应的电子衍射图中的斑点名字没区别.
那就这样改啊:
A FFT based on the HREM image was shown in Figure 1. Two spots, (0001) and (000-1), in the FFT pattern were then selected and an inversed FFT was carried out, with resulted image shown in Figure 3.
2:假设把(0001)(000-1)连线上所有的点都选中.再IFFT,又怎样表达呢?
A FFT based on the HREM image was shown in Figure 1. An inversed FFT was carried out by selecting all the spots along the[0001] direction in the FFT pattern.The resulted image is shown in.......
原文由 dianjing2006 发表:
Two spots ,能不能再仔细一下,标定的话他们分别是(0001)(000-1),他们能叫
diffraction spot吗?FFT中的斑点应该和对应的电子衍射图中的斑点名字有所区别吗?
在FFT中应该叫什么呢?
还有假设把(0001)(000-1)连线上所有的点都选中.再IFFT,又怎样表达呢?
谢谢啊!
原文由 phoenix-sun 发表:
我来试一下:
A FFT based on the HREM image was shown in Figure 1. Two spots in the FFT pattern were then selected and an inversed FFT was carried out, with resulted image shown in Figure 3.
