我的翻译基本上都是在爱鸟人士的翻译来得,改了几处我自己理解的地方。
Sample preparation
Weigh accurately 2.000 g of polymer cut into small pieces and place in a 200mL
conical flask. Slowly add 10mL of concentrated sulfuric acid, cover with a
watch glass and heat until charring is well progressed. Allow to col and add, dropwise, sufficient hydrogen peroxide(100 vols) to oxidize the charred matter and heat again. Cool, and repeat addition of hydrogen peroxide until solution remains colorless. Heat to white fumes of sulfuric acid, but do not try to greatly reduce the acid volume.
样品制备
准确称量2g聚合物,切成碎片,然后置于200ml锥形瓶中。缓慢加入10ml浓硫酸,盖上表面皿,加热烧成灰。冷却后,逐滴加入足够过氧化氢(100体积)以氧化灰化物,然后再次加热。冷却后,重复加双氧水,直至溶液变为无色。加热至硫酸冒白烟,注意不要使硫酸体积损失太多。
如果溶液是澄清的,向冷却的消解产物中加20ml蒸馏水,并转移至100ml的容量瓶中定容。这样由含0.01%Cd的样品配备的溶液中镉的浓度是2ug/mL。
如果消解过程中产生沉淀,采取另一个程序。
冷却消解液,添加20ml蒸馏水,搅拌十分钟,冷却后,使用Whatman 42纸进行过滤。
1。酸溶液
使用蒸馏水清洗沉淀物,收集滤液和洗涤液至100ml容量瓶。使用蒸馏水定容。
2。碱溶液
将置有滤纸和沉淀物的漏斗置于50ml容量瓶瓶颈处,使用EDTA饱和的20%的氢氧化钠溶液清洗,然后使用蒸馏水清洗并定容。
If solution is clear, add 20 mL of distilled water to the cool digestion mixture and transfer to a 100mL volumetric flask and make up to volume. The solution prepared from a sample with 0.01% Cd will contain 2ug/mL Cd.
For digestion with precipitate follow an alternative procedure.
Cool the digestion mixture and add 20mL of distilled water. Swirl for ten minutes, cool and filter through a Whatman 42 paper.
1.Acid solution
Wash the precipitate with distilled water collecting the filtrate and the subsequent washings in a 100mL volumetric flask. Make up to volume with distilled water.
2.Alkaline solution
Place the funnel with the filter paper and the precipitate in the neck of a 50mL volumetric flask. Dissolve the precipitate by washing the paper with 20% sodium hydroxide solution saturated with EDTA. Follow by distilled water washing and make up to volume.
如果消解过程中产生沉淀,则采取另一个步骤:
1。酸溶液
2。碱溶液
