CONJUGATION
To Indicate Addition
l additionally, again, also, and then, as can be easily understood, besides, equally important, especially, finally, for the same reason, first, further, furthermore, in addition, last, likewise, moreover, next, second, third, too, evidently, obviously, roughly speaking, broadly speaking
To Indicate Cause and Effect
l accordingly, as a result, consequently, for this reason, hence, in short, otherwise, then, therefore, thus, truly
To indicate Comparison
l in a like manner, likewise, similarly , alternatively
To Indicate Concession
l after all, although this may be true, at the same time, even though, even so , I admit, naturally, of course
To Indicate Contrast
l and yet, at the same time, but, for all that, however, yet, in fact, in contrast, in the real life, in spite of, nevertheless, notwithstanding, normally, on the contrary, on the other hand, still, traditionally, rather, unfortunately,
To Indicate Time Relationships
l after a short time, afterwards, as indicated earlier, as long as, as soon as, at last, at length, at the moment, at that time, at the same time, before, earlier, currently, immediately, in the meantime, in recent years, lately, later, meanwhile, often, of late, presently, recently, soon, shortly, since, thereupon, temporarily, therefore, until, when, while
To Indicate Special Features or Examples
l for example, for instance, incidentally, indeed, in fact, in other words, in particular, in practice, specifically, that is, to illustrate, in this respect, theoretically, as mentioned before / above
To Indicate Summary
l in brief, in conclusion, in short, in summary, on the whole, to conclude
, in general, to summarize, to sum up, as a result, ultimately,
VERB PHASE
l build a .. model
l build up the key link
l began a new era in ...
l can be regarded as / achieved / used to/for / found / obtained through
l can result in
l carries out ... tasks
l production information in order to simultaneously
l contains all information necessary to describe
l do not make use of production information
l deals with
l end with failure
l fetch the information from the model directly
l has great potential / yet to be resolved / spurred the development of /
been recognized as
l BE aimed at / built up / carried out by / essentially concerned with / considered to be the key technology / associated with each feature of a compo
site component / cable of / currently implemented for / demonstrated by an example / finally reached / made equal to / equivalent to / more suitable to / oriented to / interpreted as / pointed out / potentially of great benefit in the complex task of / shown in / used to effectively guide the search
l makes use of
l make up
l meets the needs of real life production,/ the current demands placed upon it
l must be justified
l point out
l play an important role
l relates to
l rely on
l satisfy the needs
l determine the total requirements for the ...
l uses ... as a key to search for...
l without relying on
l will be available/ performed/ overlooked
