| +---2
| | ASTM D6127-97.PDF
| | ASTM D6128-97.PDF
| | ASTM D6129-97.PDF
| | ASTM D6133-00.PDF
| | ASTM D6136-97.PDF
| | ASTM D6137-97.PDF
| | ASTM D6138-97.PDF
| | ASTM D6140-97.PDF
| | ASTM D6142-97.PDF
| | ASTM D6144-97.PDF
| | ASTM D6147-97.PDF
| | ASTM D6148-97.PDF
| | D0910-04a航空汽油技术规范.pdf
| | D0975-05柴油技术规范.pdf
| | D1152-97(2001)甲醇(甲基醇).pdf
| | D1719-05异丁醇.pdf
| | D1835-05液化石油(LP)气.pdf
| | D1836-02商品己烷.pdf
| | D2668-02红外线吸收法测定绝缘油中2,6-二叔丁基对甲酚和2,6-二叔丁基对苯酚的试验方法.pdf
| | D2880-03燃气轮机用燃料油.pdf
| | D3131-02乙酸异丙酯(99%度).pdf
| | D3734-05高闪点芳烃石脑油.pdf
| | D3735-02VM&P石油脑.pdf
| | D4150-03气体燃料及相关术语.pdf
| | D4814-02汽车火花点火发动机燃料技术规范.pdf
| | D5445-05商品贮运用图示标志的标准规定.pdf
| | D6985-04a用于军用船舶的中间馏分燃油规范.pdf
| +---3
| | D1000 – 99 Adh Tapes.pdf
| | D1002 – 01.PDF
| | D1037 – 99 Standard Test Methods for Evaluating Properties of Wood-Base Fiber and Particle Panel Materials1.pdf
| | D1062 – 96e1.PDF
| | D1084 – 97 Adh Viscosity.pdf
| | D1084 – 97.PDF
| | D1779 – 98.PDF
| | D1780 – 99.PDF
| | D1781 – 98.PDF
| | D1828 – 01.PDF
| | D1874 – 62 (Reapproved 1998).PDF
| | D1875 – 95.PDF
| | D1876 – 01.PDF
| | D1879 – 99.PDF
| | D1916 – 93 (Reapproved 1997).PDF
| | D1979 - 97 Standard Test Method for Free Formaldehyde Content of Amino Resins.PDF
| | D1994 – 95 (Reapproved 2000).PDF
| | D1995 – 92 (Reapproved 1998)e1.PDF
| | D2000 – 03.pdf
| | D2093 - 97.PDF
| | D2094 - 00.PDF
| | D2095 - 96e1.PDF
| | D2122 - 98.pdf
| | D2240 – 02b.pdf
| | D2247 – 02.pdf
| | D2293 – 96.PDF
| | D2294 – 96.PDF
| | D2295 – 96.PDF
| | D2339 – 98.PDF
| | D2464 - 99.pdf
| | D2466 – 02 Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Pipe Fittings, Schedule 40.PDF
| | D2467 – 02.pdf
| | D2513 - 04 Standard Specification for Thermoplastic Gas Pressure Pipe, Tubing, and Fittings.PDF
| | D2556 – 93a (Reapproved 1997).PDF
| | D2557 – 98.PDF
| | D2559 – 00.PDF
| | D2609 - 02 聚乙烯(PE)塑料管用塑料制插入式配件的标准规范 Standard Specification for Plastic Insert Fittings for Polyethylene (PE) Plastic Pipe.pdf
| | D2651 – 01.PDF
| | D2674 – 72 (Reapproved 1998).PDF
| | D2739– 97.PDF
| | D2851– 98.PDF
| | D2918– 99.PDF
| | D2919– 01.PDF
| | D2967 - 02a.pdf
| | D2979– 01.PDF
| | D3111 – 99 Standard Test Method for Flexibility Determination of Hot-Melt Adhesives by Mandrel Bend Test Method.pdf
| | D3121– 94 (Reapproved 1999).PDF
| | D3163– 01.PDF
| | D3164M– 98.PDF
| | D3164– 97.PDF
| | D3165– 00.PDF
| | D3166– 99.PDF
| | D3167– 97.PDF
| | D3307-06 Standard Specification for Perfluoroalkoxy (PFA)-Fluorocarbon Resin Molding and Extrusion Materials.pdf
| | D3310– 00.PDF
| | D3359–02 Standard Test Methods for Measuring Adhesion by Tape Test.pdf
| | D3426 – 97 Electric Strength.pdf
| | D3433 – 99.PDF
| | D3434 – 00.PDF
| | D3482 – 90 (Reapproved 2000).PDF
| | D3498 – 01.PDF
| | D3528 – 96.PDF
| | D3535 – 00.PDF
| | D3632 – 98.PDF
| | D3658 – 01.PDF
| | D3762 – 98.PDF
| | D3807 – 98.PDF
| | D3808 – 01.PDF
| | D3929 – 96e1.PDF
| | D3930 – 93a (Reapproved 1999)e1.PDF
| | D3931 – 93a (Reapproved 1999)e1.PDF
| | D3933 – 98.PDF
| | D3983 – 98.PDF
| | D4027 – 98.PDF
| | D4060 - 95.pdf
| | D4300 – 01.PDF
| | D4317 – 98.PDF
| | D4332 - 91 Standard practice for conditioning containers, packages, or packaging components for testing.pdf
| | D4338 – 97.PDF
| | D4339 – 01.PDF
| | D4426 – 01.PDF
| | D4497 – 94 (Reapproved 1999).PDF
| | D4498 – 00.PDF
| | D4499 – 95 (Reapproved 2000).PDF
| | D4501 – 01.PDF
| | D4502 – 92 (Reapproved 1998)e1.PDF
| | D4562 – 01.PDF
| | D4680 – 98.PDF
| | D4688 – 99.PDF
| | D4689 – 99.PDF
| | D4690 – 99.PDF
| | D4783 – 01.PDF
| | D4800 – 94 (Reapproved 1999).PDF
| | D4896 – 01.PDF
| | D4985 – 03.pdf
| | D5040 – 90 (Reapproved 1997)e1.PDF
| | D5041 – 98.PDF
| | D5113 – 97.PDF
| | D5215 – 93 (Reapproved 1999).PDF
| | D523 – 89 (Reapproved 1999).pdf
