包括很多经常有人提问的基本问题,比如: Notes on Variable Temperature Signal Suppression Tips on Locking and Shimming Spectrometer Operation Calibrating a 90° pulse lashing the Inova spectrometer for observing and decoupling different combinations of nuclei locking and shimming shimming Estimating Relaxation Times How to Reboot the Spectrometers Variable Temperature Operation Variable Temperature Operation #2 I500 Bio Setup Data Acquisition The basic parameters for a 1D experiment How to add scans to a current experiment 1H one-pulse experiment 13C one-pulse experiment Spin decoupling Signal Suppression 1D NOE experiment DEPT C13DEPT Jvert T1 inversion-recovery experiment 1H with 19F decoupling 19F with 1H decoupling homonuclear decoupling on X nuclei 13C with 1H and 2H decoupling various other double resonance experiments 2D NMR Experiments Data Processing Printing Instructions Miscellaneous Notes Guide to MestRe-C a processing and plotting program Guide to SpinWorks a spectral simulation program Guide to gNMR spectral simulation program Guide to C13 Module for calculting 13C chemical shifts How Accurate is the NOE? Product Operators for COSY experiment Relationship between Pulse Widths, Power, and Field Strength How to Save Parameters How to Change your Password 19F chemical shifts and coupling constants 31P chemical shifts and coupling constants Solvents Using the Wavetek and Oscilloscope to Tune and Match a Probe Auto-Shimming Using A Pulsed Field Gradient Along The Z-Axis VNMR on an SGI System. How Do I Do It? Converting VNMR spectra to DNMR5 format How to back up your NMR data How do I specify the font and line thickness of my plot? How do I change the font size on my printout? How do I change the line thickness of my spectra and place it into my text document? How to make a whitewashed plot? How do I print a spectrum with different colored lines? How do I print a stacked spectrum with multi-colored lines? How do I print Several Different Spectra onto one page? How do I place an inset into my spectrum and print it out? How do I create a Postscript file? How do I place a NMR spectra into a Word document using a Macintosh? How do I import a NMR spectra into a Word or Power Point document using a PC? How do I place a NMR spectra into a Word document using a PC? How do I plot a 2D homonuclear correlation (COSY, NOESY, TOCSY, etc.) type spectrum? How do I plot a 2D heteronuclear correlation (HETCOR, HMQC, HMBC, etc.) type spectrum? How do I print nice line lists on my spectra? .......
