Part # | Description | Max Frequency |
TRU-12824 | BNC(m) to QDS(f) Right Angle Adapter | 4 GHz |
TRU-11705 | BNC(m) REPLACEABLE CONNECTOR | 4 GHz |
TRU-11706 | BNC(f) REPLACEABLE CONNECTOR | 4 GHz |
TRU-11694 | BNC(f) TO SMA(m) Adapter, Straight | 4 GHz |
TRU-11695 | BNC(m) TO N(f) Adapter, Straight | 4 GHz |
TRU-11696 | BNC(m) TO N(m) Adapter, Straight | 4 GHz |
TRU-11697 | BNC(m) TO N(f) Adapter, Right Angle | 4 GHz |
TRU-11698 | BNC(f) TO N(m) Adapter, Straight | 4 GHz |
TRU-11699 | BNC(m) TO BNC(m) Adapter, Straight | 4 GHz |
TRU-11700 | BNC(f) TO BNC(f) Adapter, Straight | 4 GHz |
TRU-11693 | BNC(f) TO SMA(f) Adapter, Straight | 4 GHz |
TRU-11691 | BNC(m) TO SMA(m) Adapter, Straight | 4 GHz |
TRU-11692 | BNC(m) TO SMA(f) Adapter, Straight | 4 GHz |
SBC8281 | BNC BROADCAST GRADE BELD 8281 | 4 GHz |
361P704 | BNC Vertical PCB Jack 75OHM TEF | 4 GHz |
361ES504EFT | E-SNAP BNC Female 50 OHM | 4 GHz |
351A505 | Adapter, BNC Right Angle J/P | 4 GHz |
335R544 | Adapter, BNC ISOLATED Bulkhead F/F | 4 GHz |
335A544 | Adapter, BNC Bulkhead J/J | 4 GHz |
332A705 | Adapter, BNC F/F BARREL 75 OHM | 4 GHz |
3319505 | Adapter, BNC Male TO SMA FEMAL | 4 GHz |
3318505 | Adapter, BNC Plug TO F Jack | 4 GHz |
3309505 | Adapter, BNC Male TO SMA Male | 4 GHz |
326R515 | BNC ISOLATED Bulkhead Jack | 4 GHz |
310A205FS | BNC Cable Plug (RG58 SOLID) | 4 GHz |
310A205F | BNC Cable Plug, RG58 (STRANDED) | 4 GHz |
364A2595 | X-2 DUAL BNC Jacks Right Angle WHITE | 4 GHz |
361VH704EFT | BNC V-BITE Female-4GHZ | 4 GHz |
361V704ER | BNC V-BITE,75 OHM,TEFLON,GOLD PIN | 4 GHz |
364M795L | BNC Right Angle PC Jack-METAL LO-PROFI | 4 GHz |
364M595L | BNC Right Angle PC Jack, LOW PROF METAL | 4 GHz |
364M595 | BNC Right Angle PC Jack, STD PROF METL | 4 GHz |
364M2795 | X-2 DUAL BNC Right Angle Jacks METAL 75 OHM | 4 GHz |
364M2595 | X-2 DUAL BNC Right Angle PCB Jacks METAL | 4 GHz |
364A795BL | BNC Right Angle PC Jack, 75OHM,LOWPD,WHT | 4 GHz |
372B006 | BNC CAP & CHAIN | 4 GHz |
364A595BLB | BNC Right Angle PC Jack, LOW PROF BLK | 4 GHz |
364A595BL | BNC Right Angle PC Jack, LOW PROF WHT | 4 GHz |
364A595B | BNC Right Angle PC Jack, STD PROF BLK | 4 GHz |
364A595 | BNC Right Angle PC Jack,STD PROF WHT | 4 GHz |
364A2795B | X-2 DUAL NC Jacks Right Angle BLK | 4 GHz |
361VH704ER | BNC V-BITE NON THD,4GHZ REFLOW | 4 GHz |
364A2795 | DUAL BNC Right Angle PCB Jacks 75 OHM | 4 GHz |
364DI2595 | DUAL BNC 50 0HM DBL-ISOL | 4 GHz |
364S595M | 50 Ohm BNC Jack - Vertical Mount Bulkhead | 4 GHz |
364M2795FS | X-2 DUAL BNC METAL FULL SHLD 75 OHM | 4 GHz |
361V504EFT | BNC V-BITE W/Flange & THD 50 OHM | 4 GHz |
361V504EFT100 | 50 OHM V-BITE, 100 THICK PCB | 4 GHz |
361V504ER | BNC V-BITE For REFLOW SolderING | 4 GHz |
361V504ET | BNC V-BITE, 50, THREADED, TFE/GOLD | 4 GHz |
