主题:【求助】有一个硅样品在WOBBLER状态下无法消除重影,怎么办?
tygk98
我们用的是jem2010,一般的样品在WOBBLER状态下通过按上、下Z键,都可以消除重影。但今天的这个硅样品怎么调都无法消除重影,因而在正常状态下看起来很模糊,无法聚焦。不知大家是否遇到过这种情况?如何才能解决?
misse
possibly the sample is too thick and its thinnest area is far away from the eucentric height. Your sample profile should look like this =__=
Try to flip the sample upside down. This should fix most of the problem. You may also add a washer to keep the thinnest area at the same level with the holder axis.
